Why is THIS not a square?
« back to Hand Tools forum
Forum topic by Madmark2 posted 12-07-2020 08:07 PM 2055 views 0 times favorited 57 replies Add to Favorites Watch
View Madmark2's profile
Madmark2
3157 posts in 1874 days
12-07-2020 08:07 PM
Topic tags/keywords: question square layout
It marks perfectly perpendicular and allows parallel scribing. Some say it’s not a square and I want to know WHY?
It marks at perfect 90° – so why isn’t it a square?
If a line drawn by this matches the line from a Starrett then isn’t this a square?
-- The hump with the stump and the pump!
57 replies so far
View BlasterStumps's profile
BlasterStumps
2154 posts in 1726 days
#1 posted 12-07-2020 08:13 PM
I like it Mark, what brand is it? I’ve been looking at a few of those wondering which one to get. It would be square enough for me : ). Also wondering what length would be a good all-rounder?
-- "I build for function first, looks second. Most times I never get around to looks." MIke in CO
View OldBull's profile
OldBull
541 posts in 582 days
#2 posted 12-07-2020 08:19 PM
I took a look at these incra measuring tools and they were thin and flexible, I didn’t expect that.
View SMP's profile
SMP
4965 posts in 1192 days
#3 posted 12-07-2020 08:21 PM
That would be called a T-rule. Thats like asking why isn’t tool X called tool Y even though they can do similar things.
View northwoodsman's profile
northwoodsman
682 posts in 5032 days
#4 posted 12-07-2020 08:35 PM
I have some play in mine. If you don’t properly register the blade with the extrusion, it isn’t square. It all depends on what the item was designed for. A piece of 8.5” x 11” paper is square, but is it a “square”?
-- NorthWoodsMan
View TravisH's profile
TravisH
783 posts in 3221 days
#5 posted 12-07-2020 08:38 PM
I don’t know you should take it up with Incra.
It excels as a fine layout tool and definitely can mark something square but overall something I haven’t found much use for in my daily routine as more of a one trick pony. I doubt I have used mine a dozen times in several years. I would say it is safe to say most woodworkers would take a Starrett any day.
I would never check to see if a blade is perpendicular to a table, quickly check a joint, score a line, check a mortise depth, etc.. and all in a much more robust package compared to the Incra.
View BigMig's profile
BigMig
655 posts in 3899 days
#6 posted 12-07-2020 08:40 PM
Mark,
I use the heck out of mine, whatever it’s called. Mine’s made by Incra. But – I don’t use it to make 90 degree marks from the face. Maybe that’s why it’s not called a square.
-- Mike from Lansdowne, PA
Madmark2
#7 posted 12-07-2020 08:50 PM
Old bull:
Thin and flexible but only in one axis. Ridgid as hell in the other two. There is a perpendicular 3” end rule on them and the flex makes it easy to check in odd spaces.
Northwoodsman:
You’ll have play in your Starrett too if you don’t tighten the nut! Sheesh, what a complaint “Its loose when I don’t tighten it.” Doesn’t sound like a tool issue to me!
BigMig:
My 6” Incra rule is my most used measuring and layout device. I have the 12” and 18” versions as well but they aren’t needed too often, but all three are dead on in both directions.
View AMZ's profile
AMZ
346 posts in 675 days
#8 posted 12-07-2020 09:00 PM
I have one and I quite like it! However, I would not substitute it for a square, but for accurately running lines, it can’t be beat!. I have many squares, including Starrets. But my absolute square is a Woodpecker tri-square. The red color of heavily used tools helps in locating them.
Craftsman on the lake
3887 posts in 4724 days
#9 posted 12-07-2020 09:03 PM
I’ve had one awhile and I use it all the time.
View Loren's profile
11311 posts in 4934 days
#10 posted 12-07-2020 09:11 PM
I reckon it doesn’t meet the tolerances of INCRA’s squares so they don’t call it one. They probably don’t want to guarantee it square with the sliding arrangement. I wouldn’t if I were them.
View Rich's profile
Rich
7567 posts in 1875 days
#11 posted 12-07-2020 09:33 PM
Why is THIS not a chisel? They both have sharp beveled edges and cut wood:
View SMP's profile
SMP
#12 posted 12-07-2020 09:41 PM
- Rich
That is obviously a hammer. I use one for hammering in finish nails.
View Rich's profile
Rich
#13 posted 12-07-2020 09:44 PM
- SMP
Yes and no. But, why is THIS not a hammer?
View Rich's profile
Rich
#14 posted 12-07-2020 09:46 PM
...And why is THIS not a pry bar?
View bandit571's profile
bandit571
30065 posts in 3969 days
#15 posted 12-07-2020 10:10 PM
Willing to bet, that these are called squares…
Stanley No. 20, 8” to check a corner for…..square….
and..
Framer Square, used as a straight edge….looking for high spots…
Can the OP’s device do this….
Getting a depth stop set up to the correct depth…..
showing 1 through 15 of 57 replies
