Forum topic by Rink | posted 12-05-2020 07:00 PM | 889 views | 1 time favorited | 19 replies | ![]() |
I’ve been using BLO a lot recently to “pop the grain”. I follow that with Osmo or Poly or wax. This is a bowl that I just made (Maple, I think) that has some interesting grain. Before I BLO it again, I thought I would ask what else I can use to accentuate the grain. Thanks! David |
19 replies so far
#1 posted 12-05-2020 08:01 PM |
I never use BLO under the OMOS, sometimes a wipe of wipes with Shellac to clean up the wood? The OSMOs usually brings the grain out enough IMHO! -- Lifting one end of the plank. |
#2 posted 12-05-2020 08:29 PM |
No real use in using oil before any of the oil based combo finishes, since it already has oil. For example one of my go to finishes is Arm-r-seal. Its already half oil, so if I use BLO before its just added time and effort. |
#3 posted 12-05-2020 08:48 PM |
Kind of what SMP said, try a piece of scrap from the same board and finish one as you would with the BLO. Then also finish it with just the varnish you normally use. I highly doubt you will see a difference. -- Our village hasn't lost it's idiot, he was elected to congress. |
#4 posted 12-05-2020 09:21 PM |
never cared for blo ive always used a oil poly blend like the maloof formula or recently ive fallen in love with arm r seal. -- working with my hands is a joy,it gives me a sense of fulfillment,somthing so many seek and so few find.-SAM MALOOF. |
#5 posted 12-05-2020 10:05 PM |
Hmmm. These responses were not what I was expecting. I’ll try this bowl with just Osmo, no BLO. I don’t like ArmRSeal with a bowl, as it can get scratched too easily. But I am going to try a side by side BLO and no BLO with an oil finish. I will tip my hat to you guys, and also be surprised, if I can’t tell the difference. David |
#6 posted 12-06-2020 02:37 AM |
If it’s maple oil might turn it a yellow color. I don’t find yellow wood very attractive I guess others do because I see it here and there. -- Aj |
#7 posted 12-06-2020 06:14 AM |
This is something you may want to try, works great with just a rag and wiped on? -- Lifting one end of the plank. |
#8 posted 12-06-2020 01:07 PM |
Know lot of folks advocate using BLO in their finishing procedures. I believe it’s an unnecessary step! Any film finish (lacquer, poly, shellac, & varnish) will pop whatever grain or figure there is in surface of the wood. Same can be said for wiping varnish or oil varnish blend. You do not always have to use BLO in an oil varnish blend. -- Bill |
#9 posted 12-06-2020 01:28 PM |
But I am going to try a side by side BLO and no BLO with an oil finish. I will tip my hat to you guys, and also be surprised, if I can’t tell the difference. Good job! Run the experiment yourself and see. In my current bookcase build, I tried doing the first of the plinths without any oil, just shellac. The color is maybe a little less intense, but the time savings of not having to wait for the BLO to cure has been huge, and I find I’m happy with the finished color of four-ish coats of blonde shellac on pine. Wouldn’t have known that if I hadn’t tried it. -- Dave - Santa Fe |
#10 posted 12-06-2020 04:40 PM |
Beautiful turned bowl! Whatever you choose to put on it, it will be gorgeous. May I add that the tactile experience should also be considered? While I love wicked smooth finishes that glow, I also love when my fingers touch real wood rather than the finish. Just another factor to consider—there’s no right answer. :) -- Reasoning will never make a Man correct an ill Opinion, which by Reasoning he never acquired. --Jonathan Swift (1721) |
#11 posted 12-06-2020 04:49 PM |
I did a similar experiment with curly maple , i had about 8 different test pieces with various combos of different finishes. Using BLO vs shellac was a bit different in chattenoyance and color/tone side by side, but if you looked at them separately they both looked good. Using BLO and then Arm-r-seal side by side with just Arm-r-seal looked identical. This test was actually made me toss my danish oil and start just using ARS on most projects. But yeah its definitely a good test for anyone to do since everyone has different taste for what looks good. |
#12 posted 12-07-2020 12:26 AM |
great stuff my new fav. -- working with my hands is a joy,it gives me a sense of fulfillment,somthing so many seek and so few find.-SAM MALOOF. |
#13 posted 12-07-2020 01:26 AM |
Looking into something other than BLO for the walnut cellarette I’m building, as a test piece turned the walnut darker than I want. Its a Glen Huey project and he loves BLO followed by a couple of coats of orange shellac. I ordered some orange and garnet shellac in flakes. ** Test areas with BLO followed by 2 coats of orange and garnet – too dark. Then areas of orange and garnet followed by BLO. Then areas with the shellacs only. Gonna go with the garnet as the orange imparted a yellow cast I don’t like. Skip th eBLO.
#14 posted 12-07-2020 02:31 AM |
It depends what you plan to do with the bowl but my go-to finish for bowls that I don’t expect to be used for food or ever get wet is Mylands High Build Friction Finish. I think that it is a mix of Shellac, BLO and wax. It is best if you spend a little extra time sanding to higher grits—I usually burnish it to at least 800 grit but sometimes go all the way to 2000 so that the wood looks shiny even without a finish. You wipe on liberal coat and before it dries, buff it at high speed with a clean cloth making sure that you apply enough pressure that friction causes it to heat up. I sometimes apply a second coat but in general it is pretty much done after the you buff it. You can lightly handle it immediately but may be slightly tacky so it is best to give it a few hours to completely set and cure. After that, it is ready to go. -- Nathan, TX -- Hire the lazy man. He may not do as much work but that's because he will find a better way. |
#15 posted 12-07-2020 02:46 AM |
one thing to remember is any finish once it’s cured is food safe,i think too many worry about that for no reason.now if the surface is gonna be used too cut on,as in cutting board you need to use a mineral oil or oil wax combo that can be easily recoated,otherwise use what you like. -- working with my hands is a joy,it gives me a sense of fulfillment,somthing so many seek and so few find.-SAM MALOOF. |
Forum | Topics |
Woodworking Skill Share
13136 |
Woodturning
2781 |
Woodcarving
564 |
Scrollsawing
413 |
Joinery
1865 |
Finishing
6297 |
7850 |
32520 |
CNC Woodworking
325 |
Hand Tools
6419 |
Jigs & Fixtures
1783 |
Wood & Lumber
7240 |
1613 |
Focus on the Workspace
2610 |
1265 |
Woodworking Trade & Swap
5392 |
LumberJocks.com Site Feedback
2394 |
Coffee Lounge
9624 |
