Forum topic by Robert | posted 12-05-2020 11:32 AM | 297 views | 0 times favorited | 5 replies | ![]() |
Where do you suggest I go do replace this capacitor? Motor: Is this the run capacitor? It get extremely hot and I’ve had to push the motor reset button several times. Looks like there is some gooey stuff protruding front the end where connecting tabs are. -- Everything is a prototype thats why its one of a kind!! |
5 replies so far
#1 posted 12-05-2020 11:52 AM |
The easy thing to do is take it to a motor shop and ask for one. Sometimes when you order one on line that meets the specs, it’s a slightly different size and won’t fit into the cover. -- Our village hasn't lost it's idiot, he was elected to congress. |
#2 posted 12-05-2020 01:40 PM |
Be aware that big capacitors store a painful amount of electrical charge, so if you touch it in the wrong way you are in for an awakening, and not a good one. The bottom image looks like the motor, the top image looks like the motor run capacitor, 50 micro farad 370 volt Also note that in electrics/electronics capacitors are sometimes over stressed by other problems. |
#3 posted 12-05-2020 03:00 PM |
50uf is right range for run capacitor on a 5hp 1PH motor. Start capacitor will be ~10-12X that value. +1 Easy and best way to get replacement is to visit local motor shop Be sure to check your housing width and length, so you will know if you can use longer/larger cap if needed. Best Luck! -- If it wasn't for bad luck, I wouldn't have no luck at all, - Albert King - Born Under a Bad Sign released 1967 |
#4 posted 12-05-2020 03:13 PM |
Don’t run it until you change the cap. There is a small risk of explosion or fire. Once the cap is oozing, its done. With the saw unplugged short across the tabs with an insulated screwdriver to fully discharge the cap before servicing. -- The hump with the stump and the pump! |
#5 posted 12-05-2020 07:46 PM |
$16 with free shipping for what should be an exact replacement for that capacitor -from ebay. Can probably find them elsewhere as well. CDE 50uF CAPACITOR 370Vac on E-bay Cheers, -- Brad in FL - In Dog I trust... everything else is questionable |
Forum | Topics |
Woodworking Skill Share
13147 |
Woodturning
2785 |
Woodcarving
565 |
Scrollsawing
414 |
Joinery
1872 |
Finishing
6303 |
7861 |
32556 |
CNC Woodworking
325 |
Hand Tools
6429 |
Jigs & Fixtures
1787 |
Wood & Lumber
7245 |
1614 |
Focus on the Workspace
2618 |
1267 |
Woodworking Trade & Swap
5396 |
LumberJocks.com Site Feedback
2394 |
Coffee Lounge
9630 |
