12-04-2020 06:16 PM
Topic tags/keywords:
helical
dewalt
735
planer
upgrade
dewalt 735x
shelix
lux
lux 3
cutterhead
inserts
carbide
question
blade
I’m curious about the Lux 3 helical head for Dewalt 735 planer. Have many people pulled the trigger on this head? In fact has anyone tried the Lux-3? I don’t see much about it on the internet except one post on LJ and one vendor who sells it and the inserts.
Wondering how they are different. Does Lux 3 have the same number of cutters and rows of cutters as the Shelix?
If you bought the Lux-3, do you like it? Have you had any issues at all? In use have you seen any, even minor, scalloping (small arc shaped divots) or furrows (deeper channels left by un-even cutter or cutters) or ridges?
Was the cutterhead the same size as the O.E.M. cutterhead (hopefully) or did you need to make any changes to the depth of cut indicator? Are the bearings a solid fit, no squeeking, don’t get hot or anything?
The Lux 3 sells for a little more than the Byrd/Shllx, and has different cutters – they don’t exchange between the two. It’s supposed to have s slightly, they claim better, mounting system with better cutter seating or registration, but the cut from either should be about the same. I don’t know of anyone who has tried them side by side, but that would be interesting.
Last question: do you know if this the same as the Grizzly T31496 cutterhead or did Grizzly offer their own model and also sell this one? I’m looking to order a helical head for the 735 before Christmas finishes wiping me out. Thanks for you help and opinions!
-- I won't even try to tell other people how to live their lives: they're not listening and I'm probly wrong.
10 replies so far
#1 posted 12-04-2020 11:17 PM
I have the lux 3 on my 735. It does an excellent job.
-- Clark
#2 posted 12-05-2020 12:43 AM
I regret buying the smaller Byrd with the easy install for my DW735. While the cut quality is very good, it restricts the depth of cut I can make to approx 1/32, and it seems the rollers are crushing the wood.
-- Kjell - Eau Claire WI
#3 posted 12-05-2020 03:45 AM
- Runner
I recall seeing a YouTube commenting on the same issue—said he wish he had known about the smaller diameter before purchasing it.
#4 posted 12-05-2020 07:03 PM
- Runner
I’ve never had that issue with the lux. I typically cut 1/16 at a minimum. With no issues.
-- Clark
#5 posted 12-29-2020 03:03 PM
It’s gone out of stock for the moment, and I may be buying a project 20” bandsaw, so I’m going to save back up for the insert head. I think I will go for the Lux, OEM diameter too (all they offer for the 735 I believe.)
I’ve seen some strong arguments for a Tersa hed. They use indexed insert straight knives which are available in a variety of different, even exotic steels, and straight carbide blades. The literature makes the claim that they’re ~loose until the head spins up, and faster spinning clamps them into place even tighter. I’ll post that link when I see it again. I’m not sure it would save any money, but it was a heck of a sales pitch and worth considering…making the decision even harder! ;0
I will report back when it’s installed!
#6 posted 12-29-2020 03:28 PM
https://www.elitemetaltools.com/article/tersa-vs-xylent-cutter-heads-expert-opinion
#7 posted 12-29-2020 04:26 PM
I ve seen some strong arguments for a Tersa hed. - Rodango
I’v got 2 24” thickness planers and 2 16” jointers in the shop. 1 pair has Byrd heads in them, the other pair has Tersa’s. I agree with pretty much everything in the link you posted in regards to the Tersa’s. At the end of the day, it’s splitting hairs when comparing the 2 systems IMO. They both perform VERY well, but I’d give the advantage to the Byrd system. The Tersa knives are super fast to flip or change out, but they’re expensive compared to carbide inserts. The only reason I’ve kept the Tersa’s in use is because they only get about 30-40% of the use that the Byrd’s do. As for cut quality, on straight grained lumber, the Tersa wins every time, on anything less than straight grained like figured(even slightly) or interlocked grain, the Byrd kicks ass plain and simple. Keep in mind also that there isn’t a planer, or head made that will produce a finish ready surface. Both style heads will leave knife marks of some description. The ‘scalloping’ you referred to in your original post isn’t any more difficult to sand out than regular knife marks from straight knives. If I could only choose one style, it would be the (true) helical heads without question.
-- “Wise men speak because they have something to say; fools because they have to say something.” – Plato
#8 posted 12-30-2020 02:34 AM
I v got 2 24” thickness planers and 2 16” jointers in the shop. 1 pair has Byrd heads in them, the other pair has Tersa s.
- Tony_S
pfft….bragger! (trying to post more) :)
#9 posted 12-30-2020 11:16 AM
- LeeRoyMan
And I walks wit a swagger….when I’m bein’ a bragger…
#10 posted 12-30-2020 05:06 PM
And I walks wit a swagger….when I m bein a bragger…
- Tony_S
Fixed for you. And I walks wit a stagger….when I’m drinking a lager….. HNY
Forum |
Topics |
Woodworking Skill Share
Your woodworking skills are displayed for several lifetimes in each project. Have you had to compromise your project...
13140 |
Woodturning
On the lathe, by the lathe: do you have questions? frustrations? tips? This forum is for all the woodturners out there.
2783 |
Woodcarving
Relief, 3D, chip-carving, whittling; carving knives, chisels, pocket-knives, power tools. If you are a carver or want...
564 |
Scrollsawing
Intarsia, fretwork, intricate design cutting and more! This forum is for scrollsawers: share your tips, ask questions...
413 |
Joinery
Have a question? a tip/strategy to share? a challenge, perhaps? Share your "joinery" discussion here.
1870 |
Finishing
The finish, whether paint, wax, stain, or something else, can make or break a project. What are your tips and questio...
6303 |
Looking for information on designing your projects? Having difficulties reading project plans? Looking for help with ...
7858 |
Are you unsure of which tools, or hardware, you need, or which brands to buy? Investing in tools and hardware can be ...
32540 |
CNC Woodworking
Questions and answers about CNC machines, tooling, best practices, and projects.
325 |
Hand Tools
Wood, your hand tools, you and a little know-how. Share your questions, tips and strategies for the use and maintenan...
6421 |
Jigs & Fixtures
Using a jig is like having a couple extra hands helping out. Show us your jigs, share your tips, strategies and, of c...
1784 |
Wood & Lumber
Different wood requires different woodworking strategies - from cutting to finishing. Share your tips and challenges ...
7245 |
Before you pick up those woodworking tools, take the time to ensure your safety in the shop! Eyes, ears, fingers, and...
1613 |
Focus on the Workspace
Are you looking for or do you have tips to share regarding the workshop? Storage, equipment placement, efficiency, an...
2615 |
If you are selling your work, then you have entered a woodworking dimension with added complexity and stress. If you...
1267 |
Woodworking Trade & Swap
All of us are holding onto treasure in our shops, that we either don't need, don't want, or could part with if presen...
5394 |
LumberJocks.com Site Feedback
Connect with the Website Gurus and tell us what you are thinking, suggestions, problems, functionality issues, and so...
2394 |
Coffee Lounge
Need a break from all the standing and wood dust? Chat with your Forum Friends about their projects, their life, thei...
9626 |
