This is my second post on a Delta DJ20 Jointer that I want to buy. My first post was how to disassemble it for moving. The input I got from the forum convinced me to not disassemble the bed. I was about to buy the Jointer when I discovered it has a 3 phase motor. After doing some reading I found out there are converters available to switch one phase into three phase. Problem is loss of hp and excessive wear on the motor. I'm still considering the Jointer and changing the motor to one that is single phase, 110/220 volt. I saw a motor on eBay that is 1-1/2 hp, 110/220, tefc (totally enclosed fan cooled) and 56 mounting.. The price is $160.
Any advice would be appreciated.
- u4ic
Only if you go with a static converter. Get a VFD and you will run full HP and will be able to do other tricks not possible with just a straight 3 phase motor like soft start, controlled braking, over-torque, constant speed control, etc…. And these days, VFD's are about the same price or even cheaper than static converters, and you can get one for right around what you are looking at paying for that single phase motor.. Plus, the three phase motor doesn't have any additional crap to go bad other than bearings - no capacitors, start windings, centrifugual switches, etc… they are basically bullet proof and hard as hell to kill.
My vote would be to go with a new 1hp single phase motor and wired to 220 volt if you can.
I agree with Brad that 3 phase motors are work horses, but not needed for a home work shop.
Keep it simple and get a new motor.
Related Threads
LumberJocks Woodworking Forum
2.5M posts
96K members
Since 2006
