Forum topic by harum | posted 12-02-2020 10:18 PM | 500 views | 0 times favorited | 11 replies | ![]() |
Greetings! I have been looking for ways to improve dust collection for a hybrid Jet table saw, JPS-10TS. The shopvac and diy cyclone bin connected to the dust port catch a good portion of the dust, however, a lot shoots up in the air at the blade throat and through the slit of the blade height adjustment handwheel. Is there a good way to collect dust at the blade throat and to block other leaks? This is for a small two-car garage which is currently used only for storage and washer and dryer stuff. Any reference would be greatly appreciated! Best wishes, h. -- "If you're not counting the ripples when throwing pebbles in the water, you're wasting your time." |
11 replies so far
#1 posted 12-02-2020 11:00 PM |
You need an over arm collector. -- Everything is a prototype thats why its one of a kind!! |
#2 posted 12-02-2020 11:31 PM |
Thank you, Robert! Yes, have seen a few DIY overarms on the internet. Would a shopvac provide enough flow for both the dust port and overarm or a dedicated standalone cyclone unit is necessary? Best Wishes! -- "If you're not counting the ripples when throwing pebbles in the water, you're wasting your time." |
#3 posted 12-02-2020 11:34 PM |
probably not. Just the overarm probably though. -- The smell of wood, coffee in the cup, the wife let's me do my thing, the lake is peaceful. |
#4 posted 12-02-2020 11:55 PM |
I added the Shark Guard to my saw and the DC works pretty good but I still get some dust here and there. Happy Holidays! -- A bad day woodworking is still better than a good day working. |
#5 posted 12-03-2020 01:34 AM |
Is there a good way to collect dust at the blade throat and to block other leaks? Shark Guard: https://www.thesharkguard.com/ They were outstanding in helping me get one of their units for my 80’s vintage Craftsman 10” Flex-Drive TS. The Shark Guard will catch most of the ‘flinging’ dust, with the exception of certain cuts. -- "In the end, it's all Hack..." |
#6 posted 12-03-2020 03:24 AM |
Thank you guys! Great help, as always! I’ll contact Shark Guard to see what they have for my saw. Do I understand it correctly that with an overarm like at the photos there’s no need to also hook up the dust port at the back? -- "If you're not counting the ripples when throwing pebbles in the water, you're wasting your time." |
#7 posted 12-03-2020 03:48 AM |
I don’t have overarm dust collection. But I did get magnetic vent covers and cut them smaller to cover the opening at the crank handle, for better dust collection at the base. Covers up the slot on the base, where crank raises and lowers the blade. https://www.menards.com/main/heating-cooling/registers-grilles/deflecto-magnetic-vent-cover-3-pack/mvcx815/p-1562826573187-c-6879.htm?tid=-89581341203799162&ipos=1 |
#8 posted 12-03-2020 04:26 AM |
Thank you, WoodenDreams! Great solution for the crank handle opening, I should have thought of it. -- "If you're not counting the ripples when throwing pebbles in the water, you're wasting your time." |
#9 posted 12-03-2020 09:39 AM |
You’ll want to split the dust collection duties top/bottom. The blade collection fitting is 3D printed, so Shark Guard recommends (highly), that you have some means to support the weight of the hose attaching to it. I made up some ‘plates’ out of 3/16” ply that have magnets recessed in them. They cover the back and side (where the flex shaft enters) and work well. I just put some 2” blue painters tape on the area where the tilt wheel is. I’m still pondering a solution for that area. Maybe some brush seals? For now I collect almost all the wayward sawdust. -- "In the end, it's all Hack..." |
#10 posted 12-03-2020 03:53 PM |
I agree with the others. I collect top and bottom. -- A bad day woodworking is still better than a good day working. |
#11 posted 12-04-2020 09:10 PM |
Started with sealing all the dust leaks with magnetic mats. Removed the angle indicator, it’s kind of useless anyway when all angles are set with angle gauge. Here are the before and after photos: Still have to hear back from Shark Guard. -- "If you're not counting the ripples when throwing pebbles in the water, you're wasting your time." |
Forum | Topics |
Woodworking Skill Share
13135 |
Woodturning
2780 |
Woodcarving
563 |
Scrollsawing
413 |
Joinery
1865 |
Finishing
6297 |
7850 |
32513 |
CNC Woodworking
325 |
Hand Tools
6419 |
Jigs & Fixtures
1783 |
Wood & Lumber
7237 |
1613 |
Focus on the Workspace
2609 |
1265 |
Woodworking Trade & Swap
5391 |
LumberJocks.com Site Feedback
2394 |
Coffee Lounge
9622 |
