Forum topic by rednoblue | posted 11-30-2020 01:40 PM | 493 views | 0 times favorited | 7 replies | ![]() |
Hello, New member here although I had a membership a few years ago but I’m not much of a poster, and I do check in regularly without logging in. Thanks for all the help this forum has given me. I now have a specific issue: I have a GO715P tablesaw. Bought it lightly used. It was manufactured in 2016 so just 4 years total of light use. So I thought I would check the bearings since I can do that… bearings are fine. Capacitors seem fine (no swelling/leaking) BUT: The windings had somehow melted/fused themselves to the armature. (forgive if my terminology is off). OK, Called grizzly. Thought I would order a new motor. NO LUCK> This model discontinued and Grizzly has no motor or even any suggestions. (kinda disappointed that this new of a saw has no major parts available) Called a local motor shop and they though it would START at $600 to re wind the motor plus any other stuff it needed. NOPE! the saw is not worth that (to me) This motor has the support bracket integral to the motor as well as an adjustment bracket welded to the side so a of-the-shelf motor wont work. While I hope no one here has had this problem, I hope someone may have a solution? Thanks I |
