Scroll saw blades
« back to Scrollsawing forum
Forum topic by Ben40 posted 11-30-2020 01:36 PM 417 views 0 times favorited 12 replies Add to Favorites Watch
View Ben40's profile
Ben40
7 posts in 90 days
11-30-2020 01:36 PM
Is there any scroll saw blades that will cut a somewhat straight line? I’m really tired of having to compensate for blades that don’t cut straight. Every single blade I have tried always wants to drift.
-- Ben
12 replies so far
View Redoak49's profile (online now)
Redoak49
5025 posts in 2962 days
#1 posted 11-30-2020 02:36 PM
With a small blade you get drift. I have used many different ones and it is the same. I do not notice as I concentrate on cutting to the line.
View tomsteve's profile
tomsteve
1131 posts in 2193 days
#2 posted 11-30-2020 03:34 PM
its the nature of the beast. they cut straight just not how you may be thinking they should. gotta feed at an angle to the table a bit.
as with Redoak, ive tried a few different brands of varying geometry and # (mainly to find the one brand i like) and they all drift. i
View Davevand's profile
Davevand
231 posts in 1810 days
#3 posted 11-30-2020 05:09 PM
Pegas MG ( Modified Geometry ) blades cut about as straight as you can get a scroll saw to cut
Ben40
7 posts in 90 days
#4 posted 11-30-2020 05:13 PM
Thank you
- Redoak49
Is there any scroll saw blades that will cut a somewhat straight line? I m really tired of having to compensate for blades that don t cut straight. Every single blade I have tried always wants to drift.
- Ben40
-- Ben
Ben40
7 posts in 90 days
#5 posted 11-30-2020 05:14 PM
Thank you
- Redoak49
-- Ben
Ben40
7 posts in 90 days
#6 posted 11-30-2020 05:19 PM
What a coincidence. I ordered some Pegas blades (first time) a while ago and just received them today. I’m on my way to try them now.
Thanks for the reply and tip.
- Davevand
-- Ben
View ddockstader's profile
ddockstader
205 posts in 4235 days
#7 posted 11-30-2020 06:10 PM
Also remember that the drift angle of a small blade can be severely impacted by the grain direction. Once you compensate for the drift of the blade, if the grain changes direction, the drift may, too. The only solution is to constantly monitor your progress and adjust as necessary. (Having been a pilot for 20 years, it’s exactly the same as flying an airplane.)
Ben40
7 posts in 90 days
#8 posted 11-30-2020 06:45 PM
Also remember that the drift angle of a small blade can be severely impacted by the grain direction. Once you compensate for the drift of the blade, if the grain changes direction, the drift may, too. The only solution is to constantly monitor your progress and adjust as necessary. (Having been a pilot for 20 years, it s exactly the same as flying an airplane.)
Thanks for the reply and tips.
“Drift” As a sailor and a boat owner for many many years I understand drift. I get your point.
- ddockstader
-- Ben
View MrUnix's profile
MrUnix
8360 posts in 3172 days
#9 posted 11-30-2020 06:52 PM
Most blades are stamped, which leave a burr and cause the drift. Ground blades will not drift as much or at all… nor will spiral blades.
Ben40
7 posts in 90 days
#10 posted 12-01-2020 03:41 AM
Thanks
- MrUnix
-- Ben
View jklingel's profile
jklingel
176 posts in 2130 days
#11 posted 12-13-2020 10:01 PM
Don’t you find that once you figure out the angle at which to hold the line you are following to the blade, that you can cut pretty straight? Of course, the bigger the blade, the easier it is. I’m just starting scrolling, but an 11 or 9 sure cuts straighter than a 6. I can not keep a spiral blade straight to save my life. I’d have to clamp a guide to the table were I to need to use one for much of anything. BTW: Thanks for the info on the other blades. All I am familiar with are Olson blades, and am going to ask a ??? about blades right quick.
View OzarkSawdust's profile
OzarkSawdust
68 posts in 772 days
#12 posted 12-14-2020 02:46 AM
I switched to Pegas MG…will never go back to the others!
