Trouble with blotchy stain on wood floor
Forum topic by DummyDiy posted 11-30-2020 01:32 PM 199 views 0 times favorited 5 replies Add to Favorites Watch
View DummyDiy's profile
DummyDiy
1 post in 63 days
11-30-2020 01:32 PM
Topic tags/keywords: stain floor sanding troubleshooting help
Hi all! I’m having a hard time figuring out what’s going on with this wood floor I’m staining. It takes in the stain super dark in some places, and others are the nice “golden oak” which matches what I expect. It is duraseal golden oak I’m using, and I’ve been experimenting with different sanding techniques, but sanding doesn’t seem to make a difference. When I look at the raw wood I see these variations in color, which get accentuated to an extreme when I apply stain.
Tomorrow I might go buy a preconditioner to see how much that helps. Any thoughts?
I’m attaching an image of what it looks like after staining… then I sanded down the middle to expose what the wood looks like underneath the stain.
Also, any guesses what species this is?
5 replies so far
View Brawler's profile
Brawler
200 posts in 806 days
#1 posted 11-30-2020 01:51 PM
Try using a sanding sealer before staining. I’m not sure what kind of wood that is but looks like pine. I found sanding sealer helps a lot for a more even stain color on pine and probably on some other woods too. My turning mentor told me to use “Lacquer sanding sealer” and dilute it 50/50 with lacquer thinner, this has worked well for me.
-- Daniel, Pontiac, MI
View bondogaposis's profile
bondogaposis
5934 posts in 3327 days
#2 posted 11-30-2020 02:10 PM
Pine is very notorious for blotching. I try to avoid staining it as much as possible.
-- Bondo Gaposis
View tomsteve's profile
tomsteve
1132 posts in 2195 days
#3 posted 11-30-2020 03:45 PM
that looks like a piece of wood siding to me.
anyhoo, welcome to pine- where stains require a pre stain conditioner to stop blotchyness.
mineral spirits works good for that if using oil based stain.
View splinterhead's profile
splinterhead
12 posts in 57 days
#4 posted 11-30-2020 03:52 PM
Try applying a wood conditioner. I have made some really nice projects out of stained pine. The only way i will stain it is if it has wood conditioner.
-- Dylan, O-H-I-O
View SMP's profile
SMP
3203 posts in 881 days
#5 posted 11-30-2020 04:26 PM
I gave up on regular stains on pine. I pretty much will only use General finishes oil based gel stain. It costs more than big box stain, but you don’t need to use pre stain conditioners with it, so it actually becomes similar priced/cheaper.
