Forum topic by northern9 | posted 11-30-2020 01:27 PM | 311 views | 0 times favorited | 3 replies | ![]() |
Hello friends, For those who built the Venturi kit, what compressor model / specs are you using with it? I’m curious to hear from anyone who has built this pump and which compressor worked well (or not so well). Thanks for any input. |
3 replies so far
#1 posted 11-30-2020 06:15 PM |
I built one. I think it’s a good kit—has everything you need. I chose the “Plus” size. I’m using a Porter Cable Twin stack air compressor—here are the specs: I think my compressor works fine for this application. I don’t think you need a real powerful compressor or even anything with a large tank. The compressor should run when you first apply vacuum and then again if the vacuum drops due to leakage. My compressor only comes on once or twice in a 4 hour period during a press and runs for just a short period. I would suggest using a PTFE paste to seal the threads rather than Teflon tape. I used Teflon at first but had more leakage than I wanted so I took it all apart or used the paste and it is very tight now. |
#2 posted 11-30-2020 07:38 PM |
I assembled the kit several years ago. My compressor is a large one, but aside from the initial blast of air to draw down the bag, I think most any compressor will suffice. You’ll need some pressure (I run at 120psi) to get the last bit of inches on the vacuum gauge, but I love mine and don’t regret it versus a pump. |
#3 posted 12-02-2020 04:07 AM |
Thank you both for the detailed responses! This is really helpful. |
Forum | Topics |
Woodworking Skill Share
13136 |
Woodturning
2781 |
Woodcarving
564 |
Scrollsawing
413 |
Joinery
1865 |
Finishing
6297 |
7850 |
32520 |
CNC Woodworking
325 |
Hand Tools
6419 |
Jigs & Fixtures
1783 |
Wood & Lumber
7240 |
1613 |
Focus on the Workspace
2610 |
1265 |
Woodworking Trade & Swap
5392 |
LumberJocks.com Site Feedback
2394 |
Coffee Lounge
9624 |
