Forum topic by RothFam | posted 11-30-2020 01:25 PM | 279 views | 0 times favorited | 7 replies | ![]() |
While testing some stain colors, i applied Varathane’s American Walnut to a red oak board. After 2 hours applied a second coat of stain. After 18 hrs, I wiped on a coat of Arm-R-seal gloss and the poly wiped off the stain. |
7 replies so far
#1 posted 11-30-2020 02:53 PM |
Did you mean to post a picture? Or explain the issue? |
#2 posted 11-30-2020 03:03 PM |
Did you wipe off the excess stain after about 5 minutes? -- Nathan, TX -- Hire the lazy man. He may not do as much work but that's because he will find a better way. |
#3 posted 11-30-2020 03:34 PM |
In my experience, this is not unusual. The solvents in the poly will dissolve the stain and streak it. This is a bigger problem if you don’t sufficiently wipe off the excess stain. You can prevent the problem if you apply a thin coat of shellac Seal Coat before the poly. This “locks” the stain in place. Stains are supposed to have a binder in them for this purpose. Maybe some are more effective than others. I haven’t tested. |
#4 posted 11-30-2020 04:28 PM |
Was it gel stain you used? If not it sounds like it wasn’t wiped away enough. |
#5 posted 11-30-2020 05:22 PM |
I always wipe off the excess stain after 5 minutes as Nathan suggested. I generally wipe it off, then follow with a clean rag for a second wipe off. I also let it dry overnight, then wipe it down one more time before applying Arm-R-Seal. There still will be some stain that shows up on the applicator, but not enough that the stain on the wood looks streaky or uneven. -- Earl "I'm a pessamist - generally that increases the chance that things will turn out better than expected" |
#6 posted 11-30-2020 06:18 PM |
One thing I’ve found with Varathane stains that have sat for any length of time is they have to be stirred quite a bit. The suspended pigment settles to the bottom of the can and it can thicken up quite a bit depending on how long it sat. I use strips of plexiglass to stir so as not to lose pigment being soaked up in a piece of wood. |
#7 posted 11-30-2020 06:47 PM |
It is Varathane’s Premium stain. I did have to mix it quite a bit, there was a lot of pigment at the bottom. |
Forum | Topics |
Woodworking Skill Share
13140 |
Woodturning
2783 |
Woodcarving
564 |
Scrollsawing
413 |
Joinery
1870 |
Finishing
6303 |
7858 |
32540 |
CNC Woodworking
325 |
Hand Tools
6421 |
Jigs & Fixtures
1784 |
Wood & Lumber
7245 |
1613 |
Focus on the Workspace
2615 |
1267 |
Woodworking Trade & Swap
5394 |
LumberJocks.com Site Feedback
2394 |
Coffee Lounge
9626 |
