Forum topic by Grain21 | posted 11-30-2020 01:03 PM | 153 views | 0 times favorited | 1 reply | ![]() |
Hi. I am new to this forum. I am trying to design a system to secure a set Fixings can’t be used for heritage reasons as the faces of the interior opening I am considering using a ply lining, perhaps double 16mm and then The reason I am considering 16mm ply is that I understand its Veneer quality ply to match the hard wood edging pieces. I could only use a glue if there was a system for removing the glue The double door frame (aluminium) would be screwed every 150mm to a depth of I would be grateful for any advice. Is there a variety of ply in terms of its ‘gripability’ Is there a glue that could be used to secure the ply sheets to the travatine stone facing Would solid oak say 20mm x 100mm be appropriate for the ‘architrave’ ? Perhaps there are reasons this design wouldn’t work. An alternative solutions could be to ‘wedge’ a timber sub frame into an opening without using fixings? Thank you for your attention. |
