Forum topic by stevejack | posted 11-29-2020 03:54 PM | 202 views | 0 times favorited | 2 replies | ![]() |
I am doing some of my first pattern routing. I am using 2 pattern or flush cutting bits that are 2 fluted. Straight cutting edges. The one I am using on the ALUPANEL with is a 1/8 inch ABC Plastic sandwiched between 2 thin sheets of Aluminum, is taking a beating.. I Am thinking of investing in a 1/4 or 1/2 wide Spiral pattern cutting bit. At almost $100 its a big buy for me. Question is for any of you with the experience of doing Pattern Routing switch over to a spiral bit and what say you? |
