« back to CNC Woodworking forum
Forum topic by shoichi | posted 11-29-2020 01:14 PM | 418 views | 0 times favorited | 9 replies | ![]() |
Topic tags/keywords: cnc shapeoko Hello all, I own a Shapeoko XXL CNC and have a problem/challenge I am hoping someone can help me with. Is there a way to round/smooth the edges of these small pieces I cut on my machine without need to do it by hand? I make kids toys and Ive gotten a bunch of orders that if I were to make all of them, I would have to sand 300-400 of these small pieces each one no more than 1 to 2 inches in size. Tried tried hand sanding or even using a Dremel. Takes too long and the finished product just doesn’t look good. I would very much appreciate any suggestions or recommendations. For reference, a photo of the small pieces I cut. |
9 replies so far
#1 posted 11-29-2020 02:51 PM |
Tumble them. Try putting some in the dryer on “fluff”. A tumble bucket with BB’s? -- The hump with the stump and the pump! |
#2 posted 11-29-2020 03:50 PM |
I would be careful for pieces that small as choking hazards. Do a google search for “roundover bits for CNC” and you will find a lot of solutions and ideas. -- NorthWoodsMan |
#3 posted 11-29-2020 09:10 PM |
Use a plunge round over bit. Amana makes a few. Here is the model number for one of them Amana Tool – 56125 Amazon has them. -- Grant Wilkinson, Ottawa ON |
#4 posted 11-29-2020 09:32 PM |
Tried a router with a small bit, but never found a way to hold them safely. Then mounted a dremel upside down in a table. A mini router table if you will with a small 1/8 rounding bit. Worked ok but slow. Ended up using a sanding mop like the pic below. It will not round the edges, but it will soften them. This was the best/fastest solution I’ve found so far. Anxious to hear if anyone has a better idea. -- Don't outsmart your common sense |
#5 posted 11-29-2020 10:20 PM |
Cut it in two passes on your CNC. First pass with veining bit, 2nd pass with you current cutter. Since parts aren’t separated until 2nd pass registration should be perfect. -- The hump with the stump and the pump! |
#6 posted 12-07-2020 08:19 PM |
+1 Run the plunge round over first then cut the parts out. -- "Hard work is not defined by the difficulty of the task as much as a person's desire to perform it.", DS251 |
#7 posted 12-08-2020 12:02 AM |
How do you round both sides with this method? -- Don't outsmart your common sense |
#8 posted 12-08-2020 03:31 AM |
Ah, well, that’s a bit trickier. Depending on your setup; If your machine has calibrated reference pins or a fence you can make mirrored front and back programs. Cut the back then flip, cut the front and outlines. (Sometimes called sixth face cutting.) Some folks, without this reference, drill reference holes through the front and into the spoil board that will fit reference dowels for the flip. At work, we run nested sheets of cabinet parts on a very large industrial CNC. If we can design out any 6th face operations, that is what we do. -- "Hard work is not defined by the difficulty of the task as much as a person's desire to perform it.", DS251 |
#9 posted 12-08-2020 12:07 PM |
It depends somewhat on your CAM software. I use Vectric VCarvePro. With it, I can do two-sided machining. I do quite a bit of it. I do it as DS mentions. I drill locator dowel holes in the piece and corresponding holes in my spoil board. Take a look on Mark Lindsay’s CNC Youtube channel for details. For your project I would use the roundover bit on the top surface. Then, I would flip the piece, use the roundover on the bottom surface, then use an end mill to cut them out. -- Grant Wilkinson, Ottawa ON |
Forum | Topics |
Woodworking Skill Share
13136 |
Woodturning
2781 |
Woodcarving
564 |
Scrollsawing
413 |
Joinery
1865 |
Finishing
6297 |
7850 |
32520 |
CNC Woodworking
325 |
Hand Tools
6419 |
Jigs & Fixtures
1783 |
Wood & Lumber
7240 |
1613 |
Focus on the Workspace
2610 |
1265 |
Woodworking Trade & Swap
5392 |
LumberJocks.com Site Feedback
2394 |
Coffee Lounge
9624 |
