Advice for Large Kitchen Table Build
Forum topic by LSGss posted 11-28-2020 09:59 PM 411 views 0 times favorited 10 replies Add to Favorites Watch
View LSGss's profile
LSGss
74 posts in 2963 days
11-28-2020 09:59 PM
Hey All looking for some advice on a large kitchen table build. Image included. Wood is African mahogany. Table size is 84×39” about 1 1/4 – 1 1/2 thickness. Legs will be 3×3 and taper to 2×2. Apron I plan on making out of 5/4 material with final thickness of 1”. Apron will start at 4 1/2 inches and taper down to 3” in the middle. I am second guessing my apron size and need for reinforcement. Should I make my apron material thicker along the length to 1 1/2 inches and keep it 1” along the short length (or even make it all 1 1/2 thickness doesn’t seem at important along the short length. Should I also include some cross members (perhaps 2) along the short length of the table as additional support. Appreciate any advice. Thank you.
10 replies so far
View SMP's profile
SMP
3203 posts in 881 days
#1 posted 11-28-2020 11:31 PM
Do you already have the boards? Are you planing down rough? Is that why you don’t have the thickness? I like to get a “feel” for the wood being used and then use that to plan the rest if its not a build from plan. How are you going to attach the legs to apron and top etc? I think a good mechanical connection of apron to legs and 1” apron would be fine.
LSGss
#2 posted 11-28-2020 11:51 PM
I do have the wood already. I am milling down 8/4 mainly. I did get some 6/4 for the apron. But i dont need to necessarily use it. I usually buy extra wood. I am planning on using my domino to do fairly long floating tenons. Likely x3 8mm at 100mm length tenons if using 1” apron. If using a thicker apron then I would increase it. The table with be attach to the apron using wood cleets that i will make to allow for movement. Feel free to tell me if any part of this sounds stupid.
Thanks for the help.
- SMP
View SMP's profile
SMP
#3 posted 11-29-2020 04:15 AM
One other thing to consider is if you ever need to move it, or store it, it sure is nice having removable legs. I like the brackets with 2 bolts. There are others but these type work pretty well:
https://www.rockler.com/surface-mount-corner-brackets-for-table-aprons
Or you can make an angled piece from the apron stock and bolt the legs into that corner bracket.
View CWWoodworking's profile
CWWoodworking
1360 posts in 1155 days
#4 posted 11-29-2020 06:00 AM
Your plan is sound.
I would not make the legs removable unless that’s the only way to get it through the door.
LSGss
#5 posted 11-29-2020 06:47 AM
I agree. I am planning to attach the legs. Would you make the apron and add horizontal supports. Thanks
Your plan is sound.
- CWWoodworking
CWWoodworking
#6 posted 11-29-2020 12:52 PM
My table is 40×84 with a 1.75 thick top. 1.75” aprons. Thing is like a tank. No cross members. I don’t think they are necessary.
LSGss
#7 posted 11-29-2020 02:38 PM
Awesome thanks.
- CWWoodworking
LSGss
#8 posted 12-01-2020 12:36 AM
One more question. I’m new to dominos. The end of my apron for my joint is 36×114mm. Am I better of having three 10mm domino or just go with two 12mm.
Thanks
- CWWoodworking
View Rich's profile
Rich
6398 posts in 1565 days
#9 posted 12-01-2020 04:04 AM
- LSGss
The advantage of the 12mm domino is that you can get more depth, 12×140mm versus 10×100mm. That will make a bigger difference in strength.
View Aj2's profile
Aj2
3599 posts in 2774 days
#10 posted 12-01-2020 05:43 AM
If you haven’t bought the wood yet. Consider paying a little more and get Honduras Mahogany.
-- Aj
