Cove profile that won't interfere with Hidden Cup Hinges
Forum topic by PresidentsDad posted 11-28-2020 04:01 PM 213 views 0 times favorited 5 replies Add to Favorites Watch
View PresidentsDad's profile
PresidentsDad
147 posts in 1222 days
11-28-2020 04:01 PM
Hey all, got a question. Building some 6 inch tall solid drawer fronts and want to run a cove profile on the edges and should probably run a similar edge on my shaker panel doors I just made. Any thoughts as to what overall depth would look the best and not interfere with European 35mm hidden cup hinges? I would imagine the answer might be different for the drawer front vs. the cabinet door, but would like opinions nonetheless. :)
5 replies so far
View Madmark2's profile (online now)
Madmark2
2082 posts in 1563 days
#1 posted 11-29-2020 01:17 AM
Edge to cup is 1/8”. Cup to front is 1/4” its the front dimension that is key. If your edge is cutting in from the back edge you’re changing the over all dim.
Generally 1/4” is fine. But when in doubt cut a test piece out of scrap.
-- The hump with the stump and the pump!
View Rich's profile (online now)
Rich
6395 posts in 1564 days
#2 posted 11-29-2020 01:46 AM
- Madmark2
That’s variable depending on the hinge plate and overlay. A typical, but not fixed, value is 6mm, or slightly over 1/4”.
PresidentsDad
#3 posted 11-29-2020 02:04 AM
Hey y’all. I tried a 3/16” radius cove bit that cuts not quite 1/4” from the edge and I made it go about 1/4” deep. Then I cut the cup in. All seems to be fine.
Rich
#4 posted 11-29-2020 02:39 AM
I built some doors for a contractor I work with. The cup depth was standard, the cup set back was 6mm and I did 5/16: coves without a hitch. Keep in mind that it’s a radius, not a square cut.
You could always sketch a cross-section through the door, with the cup profile and measure the max radius that won’t intersect the cup.
If you use SketchUp, or other CAD tool, that would make it easy.
View CWWoodworking's profile
CWWoodworking
1358 posts in 1153 days
#5 posted 11-29-2020 03:16 AM
Depending on the application, Blum may have a shallow depth hinge available.
