Forum topic by MiniMe | posted 11-27-2020 05:54 PM | 1625 views | 0 times favorited | 31 replies | ![]() |
I had to remove and then rebuild a section of wall frame I do have an electric planner but from my measurements the studs have stretches where they are caved or bowed and the overall alignment is not good. They say you need 1/16” flatness error for installing large tiles and I am afraid that the electric plane is going to be way to rough for this. Hand plane and straight edge ? |
31 replies so far
#1 posted 11-27-2020 06:04 PM |
I’ve used levels and string wound around nails to figure out that sort of thing. If you have a 4 ft level that might be a good one to use. You’d be using it both to assess deviations from plumb but also straightness in the studs. You don’t need everything plumb but you do need to find the high spots. You can also shim the corners until the diagonal strings touch in the middle. Then shim from there based on those corners being in the same plane. This may be the more sensible approach than planing the studs down. |
#2 posted 11-27-2020 06:10 PM |
I have a laser level as well …I tried to use that but it is difficult to have a reference and to compare (the light will hit one of the studs and it will stop there) I was thinking about a jig that would allow me to slide a tool up and down and shave the surplus wood) |
#3 posted 11-27-2020 06:17 PM |
ah. Screw wood rails to the side of the stud and using a template guide ring use a router to remove the material to the depth you want. Whatever is left over can be removed with a chisel. |
#4 posted 11-27-2020 09:40 PM |
I think this is easier said than done. |
#5 posted 11-27-2020 09:46 PM |
Hang your cement board. Then mortar the wall and straight edge the mortar. All dips will be filled in. Same as rough plastering a wall. Some of the older plasterer/tile men would call it Darbying. |
#6 posted 11-27-2020 10:17 PM |
What’s on the other side of the wall? A carpenters way to do this is cut a notch in the stud and either shim (if bowed in) or push it in and toe nail it. However, you risk damaging the wall material on the other side. So do what bold1 said. Tilers commonly float out uneven walls and floors. Your other option is sister nailers on to the studs and bring it out level. -- Everything is a prototype thats why its one of a kind!! |
#7 posted 11-27-2020 10:52 PM |
I have read about all these methods but I don’t think they will work for this particular situation If I run a straight edge (8’ level) across the studs I am seeing different situations in different areas the above will fix a caved (C shape) stud but not one ore more that have an S profile |
#8 posted 11-28-2020 01:11 AM |
If you sister the studs like Robert said you just find the stud that sticks out the most and go from there. The easiest way is to just add more thinset where the wall is off. The extra thinset fills the gap where the stud is bowed. Not many walls are straight and flat when they get tiled. |
#9 posted 11-28-2020 02:57 AM |
when walls have to be that accurate, laminated veneer studs. |
#10 posted 11-28-2020 03:44 AM |
Robert’s advise on sistering will absolutely work. Two strings crossed in an “x” will give you a better picture of what’s going on over a broader area. LVL studs are well worth their cost for tiled walls. Especially mosaic tile. DO NOT use thinset as to fill in gaps, depressions ect. No thinset is rated or warrantied for such purpose. If you can still find a tile setter that does mud work , you wouldn’t have to do anything except make the call. And pay. He’ll make the wall flat and plumb regardless of how knarly your studs. Hard to find those guys these days though. |
#11 posted 11-28-2020 04:24 AM |
I have 16”×16”×1/2” tiles in my bathroom I know there isn’t any wall in my house that’s within a 1/16”. Laticrete has products that can go from 3/32” to 3/4” for a thick bed wall. |
#12 posted 11-28-2020 05:21 AM |
Put up your cement board then level it with the thin set. -- Tom D |
#13 posted 11-28-2020 06:03 AM |
The way I’ve done it.. I put a string across the studs, usually if there’s a protruding one it’s at the midpoint. Then use a sharp axe and tap it like a chisel down the stud until they’re in line with each other. -- The smell of wood, coffee in the cup, the wife let's me do my thing, the lake is peaceful. |
#14 posted 11-28-2020 02:10 PM |
OK I did not think about crossing two wires along the wall to see what is going on |
#15 posted 11-28-2020 03:39 PM |
A straight edge or a laser. Don’t think that you need to plane all the studs to a low point, use shims in those areas. Don’t overthink this. I can understand that 1/16” is important on a floor but their won’t be any weight or pressure on a wall. You have some wiggle room with the bonding agent, it may be thicker in some areas and thinner in others, the cement board should provide a very flat surface. -- NorthWoodsMan |
Forum | Topics |
Woodworking Skill Share
13135 |
Woodturning
2779 |
Woodcarving
563 |
Scrollsawing
413 |
Joinery
1865 |
Finishing
6297 |
7849 |
32513 |
CNC Woodworking
325 |
Hand Tools
6419 |
Jigs & Fixtures
1783 |
Wood & Lumber
7237 |
1613 |
Focus on the Workspace
2609 |
1265 |
Woodworking Trade & Swap
5391 |
LumberJocks.com Site Feedback
2394 |
Coffee Lounge
9622 |
