Forum topic by MrMenessis | posted 11-26-2020 07:14 PM | 583 views | 0 times favorited | 10 replies | ![]() |
One thing I have wanted to for such a long time is a chess board. I see lots of them being built using the end grain. I’m not sure I like that as much as “non end grain” LoL. Am I correct in that end grain solves the movement problems to an extent? And hence the popularity? I have looked into doing veneer. I can cut my own veneer, even though I haven’t as of yet. But I would rather have the squares kinda thick and the edge showing. So now I’m wondering if I go with say 2” x 1/2” think squares and glue that down to 3/4” MDF If it will hold? And then leave a small space to take up movement between playing surface and frame. I also like the look of a chamfer on each square. But that opens a whole other can of worms. Chamfer the first set of strips with the grain. Easy enough. Glue up and then do the perpendicular cut. But then you need to chamfer the end grain. I think there would be tear out at each existing chamfer. Unless you climb mill it??? So many questions, so few answers. :( Any thoughts? -- Menessis Go Brave |
