Forum topic by BillK | posted 11-26-2020 02:45 PM | 326 views | 0 times favorited | 6 replies | ![]() |
Topic tags/keywords: primer shop walls plywood shop walls Am in the process of building out my basement shop in our new home. I am installing plywood sheathing (Georgia-Pacific Plytatium if that means anything) for the shop walls. As it is sheathing grade plywood I want to use the best (not the most expensive necessarily) primer on the plywood to cover knots and other surface imperfections as well as possible. Any suggestions as to the brand/type (water-based, solvent-based) would be appreciated, especially if you have experience/first-hand knowledge. Thanks in advance! |
#1 posted 11-26-2020 02:57 PM |
There was a phase I went through about 15 years ago where I was making and selling corn hole boards, primed for a guy who did custom painting. I used at one time or another all of the commercially available primers, and came away feeling BIN (Zinsser product) was the easiest to apply, and the guy I was making for said they were a dream to paint over. The boards were spec’d to be outdoors a lot, something you don’t need to worry about, so cost could also be a consideration. -- Think safe, be safe |
#2 posted 11-26-2020 03:20 PM |
+1 on the BIN, and let it dry / cure well between coats. If you have larger knots go back and hit them again. -- Live to tell the stories, they sound better that way. |
#3 posted 11-26-2020 03:45 PM |
KILZ Primer? -- A Planer? I'M the planer, this is what I use |
#4 posted 11-26-2020 03:46 PM |
If the knots are sappy, you need the alcohol based white shellac by Zinser, at least for a couple coats over the knots. |
#5 posted 11-26-2020 03:58 PM |
Something cheap. Check on Kilz it’s on bogo fairly frequently. -- Everything is a prototype thats why its one of a kind!! |
#6 posted 11-26-2020 05:10 PM |
I think the plytanium doesn’t have knots, but if any does yeah shellac. Otherwise, any good oil-based primer works well. Zinsser cover stain, Kilz, etc. Fyi, most places will tint your primer to somewhat match your topcoat to get a better color match. If you use white primer it will make the finish coat lighter. |
Forum | Topics |
Woodworking Skill Share
13135 |
Woodturning
2780 |
Woodcarving
563 |
Scrollsawing
413 |
Joinery
1865 |
Finishing
6297 |
7850 |
32513 |
CNC Woodworking
325 |
Hand Tools
6419 |
Jigs & Fixtures
1783 |
Wood & Lumber
7237 |
1613 |
Focus on the Workspace
2609 |
1265 |
Woodworking Trade & Swap
5391 |
LumberJocks.com Site Feedback
2394 |
Coffee Lounge
9622 |
