Forum topic by kjack48230 | posted 11-26-2020 01:06 AM | 230 views | 0 times favorited | 2 replies | ![]() |
Topic tags/keywords: tablesaw So I just purchased a RT 40 and was wondering if its possible to put a single phase motor on it instead of the triple phase. Oh, also, stole it damn thing for a song, way under a grand. Need to know how big a motor I’m gonna need to properly run it. Thanks in advance. |
2 replies so far
#1 posted 11-26-2020 01:43 AM |
Delta used a proprietary motor mount on the unisaws. I don’t know if the RT 40 has the same sort of issue but it’s possible. Have a look at it. Those saws were made in Brazil by Invicta. Perhaps Delta just badged them as they were in which case you may be lucky and find the motor mount uncomplicated. |
#2 posted 11-27-2020 02:36 PM |
Single Phase possible? yes The RT40 were commonly sold with 5HP & 7.5HP motors. Newer Delta models offer a 10HP option, likely for folks spinning the 2” wide 12” OD dado blades with extended arbor. The arbor on the 12/14” saws is removable, and there are different sizes. Check your arbor closely before buying blades. Some models would support a 5/8” saw arbor, and run 8-10” blades on that machine. Which also means a 3HP motor could be used, if not sawing the 4” thick timber intended to run on that monster 14” saw blade. :-) If you have a 5HP 3PH motor, you will find it cheaper to buy a VFD; than buy a new 5HP motor. There are many threads on using VFD with 5HP motors if you want more information. Best Luck. -- If it wasn't for bad luck, I wouldn't have no luck at all, - Albert King - Born Under a Bad Sign released 1967 |
Forum | Topics |
Woodworking Skill Share
13136 |
Woodturning
2781 |
Woodcarving
564 |
Scrollsawing
413 |
Joinery
1865 |
Finishing
6297 |
7850 |
32520 |
CNC Woodworking
325 |
Hand Tools
6419 |
Jigs & Fixtures
1783 |
Wood & Lumber
7240 |
1613 |
Focus on the Workspace
2610 |
1265 |
Woodworking Trade & Swap
5392 |
LumberJocks.com Site Feedback
2394 |
Coffee Lounge
9624 |
