11-25-2020 05:27 PM
I’ve been trying to do a ton of research, definitely asked a lot of questions… finally ready to actually DO it now, though!
Context: I am renting, garage walls are drywalled+painted, I’m very beginner DIYer, garage floor slants down towards outside, studs are 24” apart.
I was looking to install the french cleat along one of my walls, let’s just say roughly 12’ wide by 8’ tall
My initial thought was to get 1/2” plywood backing (as I often see done) and then mount all my 3/4” cleats on to the plywood. Would be easier to manage/align/etc. on the floor vs fighting gravity, shimming stuff up, etc. etc. It would also protect the wall from fewer screw holes and banging/other damage as I put stuff on and take stuff off the wall. Then I’d take the panel (whatever size it ends up being) and mounting it to the wall on the studs. Only the plywood would be drilled into wall/studs, and the cleats would be glued+screwed to plywood (can you screw 3/4” into 1/2” or is the depth not really deep enough to hold?). I like that the plywood backer provides an extra surface to use, should I randomly want to nail/screw into it instead of using a cleat, or to provide a more permanent hold in an area, etc.
Other option is to just mount directly to the wall. Would focus strongly on getting the bottom cleat aligned and level on the wall, and from there use spacer blocks to put on the next level etc. etc. This would probably look cleaner though I worry it’ll be a bunch of extra holes in the wall, and the wall as a hole will surely be damaged whether just tons of surface marks or various scrapes/potential dents.
Which method would you advise for going with? And for either method, I’m going to be going across multiple studs, longer than the width of the cleat or the plywood. How would I ensure everything is secured “evenly” across the widths, so that i.e. the two ends of pieces aren’t really supported by studs, or only one side is, etc.
#1 posted 11-25-2020 05:38 PM
You are RENTING! Install nothing into the wall. Everything needs to be free standing so it can be moved or removed without a trace.
-- The hump with the stump and the pump!
#2 posted 11-25-2020 05:45 PM
- Madmark2
I have permission to drill into the walls, just need to cover up. And filing drywall screw holes should be super simple, no?
#3 posted 11-25-2020 06:06 PM
No. Patching and filling is not easy. Depending on the existing finish, number and location of holes, type of fasteners, the entire wall may need refinishing.
If you keep everything mobile it will work no matter where you move to, no having to rebuild after every move.
Wall based storage is 2D. Container based storage is 3D and holds more for a given wall space.
#4 posted 11-25-2020 06:09 PM
- Madmark2
Hmm, well I’ve never tried but I thought those tubes of spackle are pretty much designed for that and work really well? There’s ones that go on pink and dry white… fill it, let dry, lightly sand it – no?
With “typical shelving”, I’m going (maybe) still have to fasten to wall to avoid tipping over, and I end up with supporting braces in the front which sucks and makes some things less easy to access.
#5 posted 11-25-2020 06:59 PM
I ripped a 1×6 on a 45 degree angle. I used 2 screws per stud and the 2 screws evenly spaced on the cabinets. they’ve been hanging for over 5 years with no problems.
#6 posted 11-25-2020 09:26 PM
I’d recommend screwing into the studs as well. Depends, I suppose, on what you plan to hang from the cleats. I’d be concerned about 1/2” plywood not having enough strength to withstand a decent load.
The plywood protecting the wall is a good point, but I’d still attach the cleats to the studs through the plywood.
For what it’s worth, I’ve never had a tough go of patching screw holes. I find painting a pain in the posterior but that’s my cross to bear. :-)
-- Gary, Wisconsin
Forum |
Topics |
Woodworking Skill Share
Your woodworking skills are displayed for several lifetimes in each project. Have you had to compromise your project...
13147 |
Woodturning
On the lathe, by the lathe: do you have questions? frustrations? tips? This forum is for all the woodturners out there.
2785 |
Woodcarving
Relief, 3D, chip-carving, whittling; carving knives, chisels, pocket-knives, power tools. If you are a carver or want...
565 |
Scrollsawing
Intarsia, fretwork, intricate design cutting and more! This forum is for scrollsawers: share your tips, ask questions...
414 |
Joinery
Have a question? a tip/strategy to share? a challenge, perhaps? Share your "joinery" discussion here.
1872 |
Finishing
The finish, whether paint, wax, stain, or something else, can make or break a project. What are your tips and questio...
6303 |
Looking for information on designing your projects? Having difficulties reading project plans? Looking for help with ...
7861 |
Are you unsure of which tools, or hardware, you need, or which brands to buy? Investing in tools and hardware can be ...
32556 |
CNC Woodworking
Questions and answers about CNC machines, tooling, best practices, and projects.
325 |
Hand Tools
Wood, your hand tools, you and a little know-how. Share your questions, tips and strategies for the use and maintenan...
6429 |
Jigs & Fixtures
Using a jig is like having a couple extra hands helping out. Show us your jigs, share your tips, strategies and, of c...
1787 |
Wood & Lumber
Different wood requires different woodworking strategies - from cutting to finishing. Share your tips and challenges ...
7245 |
Before you pick up those woodworking tools, take the time to ensure your safety in the shop! Eyes, ears, fingers, and...
1614 |
Focus on the Workspace
Are you looking for or do you have tips to share regarding the workshop? Storage, equipment placement, efficiency, an...
2618 |
If you are selling your work, then you have entered a woodworking dimension with added complexity and stress. If you...
1267 |
Woodworking Trade & Swap
All of us are holding onto treasure in our shops, that we either don't need, don't want, or could part with if presen...
5396 |
LumberJocks.com Site Feedback
Connect with the Website Gurus and tell us what you are thinking, suggestions, problems, functionality issues, and so...
2394 |
Coffee Lounge
Need a break from all the standing and wood dust? Chat with your Forum Friends about their projects, their life, thei...
9630 |
