How would you make this crown?
Forum topic by Robert posted 11-25-2020 03:05 PM 364 views 0 times favorited 8 replies Add to Favorites Watch
View Robert's profile
Robert
4330 posts in 2456 days
11-25-2020 03:05 PM
Need a profile compatible with Shaker style kitchen doors. This is what I’ve come up with but I’m open to suggestions.
I’m thinking I would make it as shown if you can decipher what I drew. I will be painted. I’m thinking glue and pin nail the bevelled strips on.
8 replies so far
View Axis39's profile
Axis39
405 posts in 573 days
#1 posted 11-25-2020 05:07 PM
I’d do two square blocks attached to a piece with angles on each end… fewer angled pieces to make.
This would also keep the pieces you’re putting angles on larger. Much safer operation, and easier to get consistent results.
-- John F. SoCal transplant, chewer uppper of good wood
View GaryCN's profile
GaryCN
497 posts in 4910 days
#2 posted 11-25-2020 06:27 PM
I think it could be done with a bird’s mouth Octa Router bit, make the entire cylinder then trim the horizontal and vertical face. That would make your glue-up a lot easier. especially clamping as you could use large worm drive hose clamps. Sized right one glue-up would yield 4 sections.
https://www.infinitytools.com/birds-mouth-router-bits-3729
-- Quando Omni Flunkus Moritati
GaryCN
#3 posted 11-25-2020 06:30 PM
Cut as marked with tape.
View hcbph_1's profile
hcbph_1
86 posts in 290 days
#4 posted 11-25-2020 06:51 PM
Perfect job for a molder like the Shopfox or W&H. You can get cutters either existing or custom ground to our profile. Do the back then do the front.
Just a thought.
View 987Ron's profile
987Ron
231 posts in 292 days
#5 posted 11-25-2020 07:13 PM
+1 Axis
-- It's not a mistake it's a design opportunity
Robert
#6 posted 11-25-2020 10:03 PM
Axis I like it.
I’m thinking rough cut and clean up with a large chamfer.
View SMP's profile
SMP
3203 posts in 881 days
#7 posted 11-25-2020 11:11 PM
I usually just buy molding. Its usually not worth my time compared to the cost and look of professional moldings. I’d be worried that that would look to “blocky” and when it separates in various areas you have an unsightly crack.
Robert
#8 posted 11-26-2020 12:09 AM
SMP I don’t know who would carry it. I’ve seen cove crown but not flat like this.
But I do plan to check with my supplier. Thx.
