Q about Incra Miter Express
Forum topic by HarveyDunn posted 11-25-2020 02:44 PM 363 views 0 times favorited 3 replies Add to Favorites Watch
View HarveyDunn's profile
HarveyDunn
417 posts in 2700 days
11-25-2020 02:44 PM
Anyone using the Incra Miter Express sled? I know they sell replacement panels for the kerf side. If I buy one sled and one replacement panel, can I set the latter up for cuts with the blade angled at 45 degrees and then swap that panel in and out with the 90 degree one?
3 replies so far
View Peteybadboy's profile
Peteybadboy
2838 posts in 2919 days
#1 posted 11-25-2020 07:55 PM
I would think not. I have the 5000 and 1000hd on sleds. Also which way does you saw tilt? Either way the sled would be week at the kerf with a 45 deg. cut. I build a 45 deg sled dedicated for that purpose.
-- Petey
View hairy's profile
hairy
3191 posts in 4501 days
#2 posted 11-25-2020 10:12 PM
I have the miter express with the 1000HD. I use a shop made sled for 45 degrees.
I would ask Incra that question.
-- You can lead a horse to water, but you can't tie his shoes. Blaze Foley
View Smirak's profile
Smirak
109 posts in 1487 days
#3 posted 11-27-2020 04:06 PM
I believe you would have to replace “both pieces” when you wanted to cut 45s. The piece that actually attaches to the sled and the drop panel. Now I believe that both pieces are “made” when setting up your sled the first time (it’s been a few years). I think it would be productivity prohibitive to switch out both each time. As others have said, just make a dedicated 45 sled…
