Forum topic by jody495 | posted 11-24-2020 11:27 PM | 455 views | 0 times favorited | 9 replies | ![]() |
Hello woodworkers. I would like your thoughts are about wiping down boards with water to raise the grain between sanding. Thank you |
9 replies so far
#1 posted 11-24-2020 11:30 PM |
I’ve done it when using water based stains and dyes. Otherwise I don’t remember doing it much. |
#2 posted 11-24-2020 11:53 PM |
as loren said only when using water based products which i rarely do. -- working with my hands is a joy,it gives me a sense of fulfillment,somthing so many seek and so few find.-SAM MALOOF. |
#3 posted 11-25-2020 01:12 AM |
If your finish will be nitro lacquer, it’s pretty standard to use a “damp” cloth to raise the fibers and cut them off by sanding prior to spraying. No experience with other finishes but works great for guitars! -- Darrel |
#4 posted 11-25-2020 05:39 AM |
Also helps with shellac, which also raises the grain, although I rarely bother. Instead I sand back the first 2 coats. -- Rick M, http://thewoodknack.blogspot.com/ |
#5 posted 11-25-2020 10:34 AM |
Thanks for the information. |
#6 posted 11-25-2020 11:39 AM |
I know people do it, but IMO there is no advantage of wetting prior to using a water based dye or stain. -- Everything is a prototype thats why its one of a kind!! |
#7 posted 11-25-2020 01:52 PM |
If you wait until you apply your first film coat, then smooth it…..it locks the fibers in place and you’re good to go. -- Our village hasn't lost it's idiot, he was elected to congress. |
#8 posted 11-25-2020 05:48 PM |
If I want a smoother finish, I raise the grain, doesn’t matter what kind of finish. I like to raise the grain whenever doing water or alcohol based finishes. I also only raise the grain up to 180 or 220. Rarely do I go beyond that, and definitely not prior to staining. When doing oil finishes, I will sand in the first coat a lot of the time to fill in the pores. But, that’;s a whole different thing. -- John F. SoCal transplant, chewer uppper of good wood |
#9 posted 11-25-2020 07:08 PM |
I use a spray bottle with water and set it out in the sun to dry. I do it with almost every project. Seems to work well for me. |
Forum | Topics |
Woodworking Skill Share
13135 |
Woodturning
2780 |
Woodcarving
563 |
Scrollsawing
413 |
Joinery
1865 |
Finishing
6297 |
7850 |
32513 |
CNC Woodworking
325 |
Hand Tools
6419 |
Jigs & Fixtures
1783 |
Wood & Lumber
7237 |
1613 |
Focus on the Workspace
2609 |
1265 |
Woodworking Trade & Swap
5391 |
LumberJocks.com Site Feedback
2394 |
Coffee Lounge
9622 |
