Forum topic by AliceAforethought | posted 11-23-2020 08:28 PM | 389 views | 1 time favorited | 12 replies | ![]() |
Hi Everyone, Just bought and adjusted my new bandsaw, Rikon 10-3061. I am using the factory 3/8 inch installed blade for now, as I am new to bandsaws and just want to get used to the saw, and learn what it can do. My first attempt to do a gentle “S” curve cut on the saw (on 3/4 inch pine board) resulted in the blade coming off the wheels. I thought it was tensioned enough, but I guess not!! Live and learn… Anyway, I re-adjusted the tension, and my second attempt did not have such drastic results, but I noticed the blade still turned as I rounded the first “S”. It was apparent that the blade was straining again, so I stopped. Is a 3/8 inch blade too wide for cutting curves? Folks on YouTube make the cuts look so effortless. Or, is my technique wrong? I hope I provided enough information, and thanks in advance for your replies. |
12 replies so far
#1 posted 11-23-2020 08:42 PM |
I can’t remember where I saw it (probably a blade selection guide) that lists the maximum radius curve for each size bandsaw blade. You need to also have the right amount of flow while turning as you are cutting. Look up Alex Snodgrass Bandsaw Reindeer in YouTube to get an idea what’s possible. |
#2 posted 11-23-2020 08:43 PM |
It depends on how sharp a curve you are trying to cut. In general, you should let the blade determine how tight a curve it can take. If it resists you are taking too sharp a turn. FYI – many of us use a 3/16”- 4tpi blade for general bandsaw cutting. -- Phil Allin - There are mountain climbers and people who talk about climbing mountains. The climbers have "selfies" at the summit! |
#3 posted 11-23-2020 08:46 PM |
Hi Alice! -- Charlie J81 |
#4 posted 11-23-2020 08:54 PM |
I am new and learning as well. This is woodcrafts explanation page for blades and list the 3/8 as a 1 – 7/16” radius. Alex Snodgrass’s video for setup will teach you as well. |
#5 posted 11-23-2020 09:17 PM |
Everything you really need is right here in these two links. Start with the Alex Snodgrass video. It is a great video and will have your saw tuned perfectly.
-- John |
#6 posted 11-23-2020 10:02 PM |
Cheers, -- Brad in FL - In Dog I trust... everything else is questionable |
#7 posted 11-23-2020 10:25 PM |
I would like to suggest getting a new blade . The blades sent out with many different saws are usually junk. Not just Rikon . -- Aj |
#8 posted 11-23-2020 10:36 PM |
Thanks everyone for your replies! I’ll start by watching the Snodgrass video first. |
#9 posted 11-23-2020 10:56 PM |
Just curious, what size balde do y’all use as you “go to” blade for routine cutting (not resaw)? |
#10 posted 11-24-2020 12:39 AM |
Alice The Alex Snodgrass video on tuning up a bandsaw will take a lot of the guess work out of it. His message is to center the gullet of the blade on the upper wheel. Most of us use 3/16, 3/8 and 1/2 wide blades on 14” bandsaws. There is not a one size fits all, for all projects. TPI, teeth per inch plays into the equation as well. Olsen, Timberwolf make good blades. Carbide blades exist, but they are expensive. They last longer, you will have to chase that tiger’s tail on your own to know what is right for you. Your saw guides are adequate for now, but they will wear out. When they do consider a set of Carter guides for your saw. I have wanted to change mine for a long while but waited until the saw told me it was time to change. I just did that within the last month, made a noticeable difference. It took about 20 minutes of reading thru the instructions and about 20 minutes of changing out the old guides. Two of the bottom bearings were seized. It is time, effort and money well spent. No regrets. |
#11 posted 11-24-2020 12:40 AM |
I have a 3/8” on as a matter of course on my 17” saw. Have never tried a 3/16” and only rarely 1/4”. For most curves, it works great. For tight curves, I go to 1/4” but tight curves mean different things to different people. I use Viking/Timberwolf blades mostly along with a few Olsen’s. -- Darrel |
#12 posted 11-24-2020 04:57 PM |
For that small saw I would use a narrow blade, 1/8, 3/16 or 1/4 with a 10 or 14 tooth count. For my saw the 1/8 inch blade tend to break to easily so I use a 3/16 14 tooth blade for all my small projects |
Forum | Topics |
Woodworking Skill Share
13147 |
Woodturning
2785 |
Woodcarving
565 |
Scrollsawing
414 |
Joinery
1872 |
Finishing
6303 |
7861 |
32556 |
CNC Woodworking
325 |
Hand Tools
6429 |
Jigs & Fixtures
1787 |
Wood & Lumber
7245 |
1614 |
Focus on the Workspace
2618 |
1267 |
Woodworking Trade & Swap
5396 |
LumberJocks.com Site Feedback
2394 |
Coffee Lounge
9630 |
