Forum topic by NLarson801 | posted 11-23-2020 07:11 PM | 321 views | 0 times favorited | 11 replies | ![]() |
I recently acquired a used Wen drill press. I used it to drill some small holes without any issues, but when I tried using a 1/2” bit I get a ton of chatter and as you can see in the video below the entire chuck fell out. This happened to me a few times even after cleaning the mating surfaces on the chuck and driving it back on. The drill seems to be spinning straight and I cannot see any wobble. Being that this is my first drill press I am unsure how to fix or troubleshoot the issue. |
11 replies so far
#1 posted 11-23-2020 08:37 PM |
a couple things to determine is the bit sharp and was the speed correct for the bit used. -- working with my hands is a joy,it gives me a sense of fulfillment,somthing so many seek and so few find.-SAM MALOOF. |
#2 posted 11-23-2020 08:51 PM |
I used the guide in the pulley area to select the speed for the bit size in wood. I believe they recommended the highest speed. The bit, I am not 100% on that, maybe I need a bit sharpener. |
#3 posted 11-23-2020 08:51 PM |
How are you driving it back on? I usually raise the table up , stick a block of wood between and crank down the lever to press it in. I once had one that had a scratch that kept it from mating well. I had to use wet dry paper with 3 in 1 oil to sand it smooth. |
#4 posted 11-23-2020 09:06 PM |
Do not use lube on shaft, shaft must be cleaned and dry when installed, no slippery stuff !!! Watch at 3 min and 30 sec into video, |
#5 posted 11-23-2020 09:16 PM |
I used a block of wood and a hammer to drive it back on. And I made sure the mating surfaces are clean and dry before doing so. the vibrations are what are causing it to come loose again. |
#6 posted 11-23-2020 09:27 PM |
I think it is either the bit (the tip looks funny when it first starts) or it’s the music !!!!!! |
#7 posted 11-23-2020 09:47 PM |
Probably the music, but I am thinking the grinding isn’t the bit on the wood, but is the chuck itself spinning on the taper. If it’s falling apart, this makes sense as well. Are you certain the stub, and the chuck are matched, and correct for the drill press? I like that video the Old Bull posted, watch, and do exactly what they show. Generally “IF” the parts involved are correct, this is a quick, painless procedure. https://www.youtube.com/watch?v=VnXGy_-SAGk -- Think safe, be safe |
#8 posted 11-23-2020 10:07 PM |
Well since the drill press was purchased second hand I can not guarantee that the stub and the chuck are a matched pair. That procedure in the video is pretty much the same as what I did. I did not completely remove the spindle from the drill press housing though. Maybe I will pick up a drill sharpener and see if the bit is just too dull. Are the drill doctors good? |
#9 posted 11-23-2020 10:07 PM |
Deftones are a great band!!!! |
#10 posted 11-23-2020 10:34 PM |
A properly sharpened bit will go thru that wood in a second or 2. |
#11 posted 11-23-2020 11:05 PM |
yeah it looked pretty dull to me. -- working with my hands is a joy,it gives me a sense of fulfillment,somthing so many seek and so few find.-SAM MALOOF. |
Forum | Topics |
Woodworking Skill Share
13147 |
Woodturning
2785 |
Woodcarving
565 |
Scrollsawing
414 |
Joinery
1872 |
Finishing
6303 |
7861 |
32556 |
CNC Woodworking
325 |
Hand Tools
6429 |
Jigs & Fixtures
1787 |
Wood & Lumber
7245 |
1614 |
Focus on the Workspace
2618 |
1267 |
Woodworking Trade & Swap
5396 |
LumberJocks.com Site Feedback
2394 |
Coffee Lounge
9630 |
