Forum topic by willhime | posted 11-18-2020 11:57 PM | 479 views | 0 times favorited | 5 replies | ![]() |
I have a rare model of the jet jwbs -18” bandsaw. Made in Taiwan it has 1.5 hp instead of the usual 1.75 for this size/model. After my blade broke the other day resawing a 10’ 2×4 (very stupidly I was pushing it a little faster than the machine wanted to cut), I replaced with a new blade. I noticed no matter how much tension or tilt adjustment to the top wheel I did, the blade sits I little forward on the bottom wheel. Since the bottom wheel doesn’t have adjustment (I’m assuming) I’m considering using a grade 8 washer to shim it out 1/16-1/8”. After rewatching snodgrass’ famous bandsaw video a couple times, I couldn’t find anything to help remedy this situation which is concerning to me given his point that the deepest part of the gullet should be in the center of the wheel, not the blade center on the center of the wheel. I can’t measure coplaner due to the construction of the machine- the housing for both wheels is proud of both of them. The thing that gives me trepidation about just using the bandsaw as is (it runs fine for minutes on end now) is that the blade positioning being different will eventually stress the blade metal and brake it probably sending me to ER. A couple years back my router table had words with me after flush trimming the outer edge of a small round table top. When I told the nurse that i was a woodworker he looked at me like a motorcycle driver and had a ‘that checks out’ look on his face, before informing me that the vast majority of woodworker ER visits are bandsaw related. Images: -- Burn your fire for no witness |
