Forum topic by RuffWoodGal | posted 11-16-2020 07:30 PM | 522 views | 0 times favorited | 25 replies | ![]() |
Topic tags/keywords: cedar untreated bathroom My husband and I just installed untreated cedar planks on two walls in the bathroom. Not sure what kind of cedar it is but we harvested it ourselves in Northern Ontario. It was cut through our own sawmill and the boards were then passed through a 10” planer with some bark still on it. There is good ventilation in the bathroom, the mirror doesn’t fog up during showers. We want to keep that lovely cedar smell but are unsure if the wood will mold or turn grey. Should the cedar be sealed or left untreated? UPDATE Thank you all for the replies, they are much appreciated. I did some research and it’s Eastern White Cedar. It doesn’t come in contact with water, it would mostly be steam from the shower. Ventilation is good as we shower with the door open (no kids in thr house). The boards were cut with the bark still on at a half inch thickness then planed. It’s installed board and batten style. It’s been up for about 2 weeks now and it still smells nice. I’m worried about it turning grey as we used some cedar beams for the loft at camp and they turned dark grey within a couple of months. |
25 replies so far
#1 posted 11-16-2020 08:12 PM |
The smell will eventually fade. -- Aj |
#2 posted 11-16-2020 09:44 PM |
Wood and a bathroom come down to how wet will the wood be, AND the species of wood. Many don’t tolerate wet/water/moisture at all. I agree with Aj it’s likely WRC, and it has quite a bit of moisture resistance. But a good running fan will take away the steam pretty quickly, I believe you would only see a problem left untreated if it stayed wet a lot. Color will probably go to gray and the smell will dissipate, but you can sometimes get it back with sanding it, and reopening it’s pores. This works much better for Eastern Red Cedar ERC. I too applaud your use of your own wood, it’s great you have the option, and the equipment. Eastern Red, or Aromatic Cedar Eastern Cedar with characteristics. Welcome to Lumber Jocks. -- Think safe, be safe |
#3 posted 11-16-2020 10:35 PM |
i put t&g cedar on the ceiling in both our bathrooms and just sealed them with a water sealer like thompsons which didn’t change the color much and had no sheen.it will kill the smell but that will fade anyway.it’s been over 18 years and there is no graying at all. -- working with my hands is a joy,it gives me a sense of fulfillment,somthing so many seek and so few find.-SAM MALOOF. |
#4 posted 11-17-2020 03:20 AM |
I’d guess it would be Juniper (way more smell than WRC) or Emerald cedar as WRC doesn’t grow in Ontario. -- Darrel |
#5 posted 11-17-2020 03:30 AM |
Did you tongue and groove it? Or just butt together? From the sound of reading it most likely issue will be shrinking as it dries and leaving gaps. |
#6 posted 11-20-2020 06:52 AM |
Most of the places a WRC will grow are listed by the Dept of Ag, under The US forest service, and like any gubmit agency they speak in generalities. Believe me, WRC grows in many areas not out west. It’s the same as a guy in Idaho who has Walnut trees (Juglans nigra) out the wazoo. Trees really don’t like always, and never, they grow where they find temperature range, and soil conditions that meet their needs, and even then they are often a lot more flexible than some people believe them to be. Now their inherent home range may be one place, but trees grow where they like it. -- Think safe, be safe |
#7 posted 11-20-2020 10:21 AM |
Smartest guy in the room, as usual… -- “Wise men speak because they have something to say; fools because they have to say something.” – Plato |
#8 posted 11-20-2020 10:57 AM |
I’ve lined a couple closets and a hallway with cedar. The smell will go away quickly. So I would be doing it for looks, not the aroma. The wood is pretty, I would seal it but you could probably leave it bare with no issues. -- Everything is a prototype thats why its one of a kind!! |
#9 posted 11-20-2020 06:08 PM |
I would point out that steam Saunas are usually made with cedar but it is Western Red Cedar or it’s look alike Incense Cedar which is quite similar but softer in texture, sometimes called pencil wood…used for pencils. They also do not have much odor and it dissipates quickly. I agree neither of these would grow in Northern Ontario. In all likelihood you have Eastern Red Cedar which is “native” to your area and has a prominent odor. The other in your area would be Eastern white cedar. I think it would be OK to use it in the bathroom unfinished but I would want it planed and sanded to a smooth surface. Actually any top coat could become a maintenance problem in a moist environment like a bathroom. If you like the cedar odor you can purchase Cedar oil and drip some on a wood block in n open container as needed….don’t put on the wall. -- Les B, Oregon |
#10 posted 11-21-2020 12:50 AM |
Eastern Red Cedar is Juniper which is also pencil wood. :) -- Darrel |
#11 posted 11-21-2020 12:59 AM |
id dont think the op really cares what kind of cedar it is,she just wants to know if she should seal it or not.so why all the debate what kind of wood it is? we dont need the “smartest” guy in the room to figure it out since no one knows,do we? -- working with my hands is a joy,it gives me a sense of fulfillment,somthing so many seek and so few find.-SAM MALOOF. |
#12 posted 11-21-2020 01:41 AM |
id dont think the op really cares what kind of cedar it is,she just wants to know if she should seal it or not.so why all the debate what kind of wood it is? we dont need the “smartest” guy in the room to figure it out since no one knows,do we? Apologies. You are correct! :) I’ll flip you for who buys the beer. -- Darrel |
#13 posted 11-21-2020 01:52 AM |
None of the Cedars mentioned above are really cedars. Most are in the cypress family. -- Aj |
#14 posted 11-21-2020 01:56 AM |
Spanish cedar is another not true cedar that I love for some things although the taste stays for quite a while regardless of DC quality. Closer to mahogany than cedar. Doh! Being a little too cerebral again. :) -- Darrel |
#15 posted 11-21-2020 02:04 AM |
id dont think the op really cares what kind of cedar it is,she just wants to know if she should seal it or not.so why all the debate what kind of wood it is? we dont need the “smartest” guy in the room to figure it out since no one knows,do we? you sure about that because i flip for premium bourbans,well aged!!! -- working with my hands is a joy,it gives me a sense of fulfillment,somthing so many seek and so few find.-SAM MALOOF. |
Forum | Topics |
Woodworking Skill Share
13131 |
Woodturning
2775 |
Woodcarving
563 |
Scrollsawing
413 |
Joinery
1862 |
Finishing
6294 |
7847 |
32507 |
CNC Woodworking
325 |
Hand Tools
6418 |
Jigs & Fixtures
1782 |
Wood & Lumber
7236 |
1612 |
Focus on the Workspace
2609 |
1265 |
Woodworking Trade & Swap
5390 |
LumberJocks.com Site Feedback
2394 |
Coffee Lounge
9620 |
