Forum topic by arhitekt | posted 11-10-2020 06:53 PM | 436 views | 0 times favorited | 7 replies | ![]() |
Topic tags/keywords: finishing finish white stains Hello everybody, I have purchased second hand table which is in pretty good shape except it has some issues on its finishing. I am not sure what could be the reason for the white stains all over it but I would like to remove them somehow. Does anybody know is it possible to fix it and how. Thanks! |
7 replies so far
#1 posted 11-18-2020 01:11 PM |
I don’t know what caused it that depends on the finish. Strippers over veneer can be risky I would start by sanding it with something like 220. Don’t go near it with a sander do it by hand. You might be able to lightly sand and apply a coat of poly. Worth a try. -- Everything is a prototype thats why its one of a kind!! |
#2 posted 11-18-2020 08:35 PM |
Looks like a water-based polyacrylic applied with a spray gun. The directions only mention using a brush and not over-brushing. -- Phil Allin - There are mountain climbers and people who talk about climbing mountains. The climbers have "selfies" at the summit! |
#3 posted 11-19-2020 09:25 AM |
Welcome to LumberJocks! That looks like lacquer blush? Lacquer turns milky when moisture in trapped in the coating. Before I would start sanding, I would test in hidden spot for lacquer finish? While it is rare to happen indoors, fully dried lacquer can turn milky if water sits on surface long enough, or bottom was not sealed and moisture is sweating up due high heat and trapped moisture in wood. Lacquer does not cure, and can melt or reflow the coating with proper lacquer thinner. BORG lacquer thinner won’t work well, need real lacquer thinner from industrial coatings supplier. When Blush happens during finishing, simply add some retarder, and spray a light coat to lacquer to magically release the moisture. Or can spray straight lacquer thinner with retarder to keep same film thickness. Higher local humidity, the more retarder solvent needed to slow lacquer thinner evaporation and let moisture escape before the lacquer finish dries. Mohawk sells a No Blush in spray cans for repairing lacquer blush on finished items. Best Luck. -- If it wasn't for bad luck, I wouldn't have no luck at all, - Albert King - Born Under a Bad Sign released 1967 |
#4 posted 12-01-2020 09:17 AM |
Thank you for your replies. Since I live in Dubrovnik, Croatia (a.k.a. King’s Landing from the Game of Thrones), there are no specialized shops where I could buy something as you mentioned. Anyway, maybe I will try to remove old finisih one day but at the moment my father installed dark brown glass to cover the stains and it looks fine. |
#5 posted 12-01-2020 01:04 PM |
Since I live in Dubrovnik, Croatia (a.k.a. King s Landing from the Game of Thrones).... Croatia location changes everything. Suggest you look for AkzoNobel wood coatings distributor in your area. Another tip: Lacquer no-blush solvent is not a magic potion. It is simple (to chemist) blend of solvents. Lacquer paints were extremely popular in mid 1900’s for automotive finishing. Another potential source of no-blush solvent blend would be automotive finish supplier like Axalta distributor. They have several country specific brands of auto paint, so usually best to call or visit. If you can’t find Lacquer no—blush product, can always buy raw solvents from Automotive paint store and make you own using Mohawk SDS as guide. Best Luck. -- If it wasn't for bad luck, I wouldn't have no luck at all, - Albert King - Born Under a Bad Sign released 1967 |
#6 posted 12-02-2020 07:54 PM |
I agree with the CaptK…it looks like lacquer blush. Test a hidden spot to determine if it is lacquer. If it is a light spray coat of lacquer thinner could solve the issue by softening the finish enough to allow the moisture to escape, then it will dry clear. -- Sam Hamory - The project is never finished until its "Finished"! |
#7 posted 12-02-2020 08:22 PM |
Another name to search for is “blush eraser” which is a spray that will reflow lacquer and allow trapped moisture to escape. Mohawk or Behlen are brands that offer this product. Perhaps a local brand will have something similar. Good luck. -- I love the smell of sawdust in the morning. |
Forum | Topics |
Woodworking Skill Share
13147 |
Woodturning
2786 |
Woodcarving
565 |
Scrollsawing
414 |
Joinery
1872 |
Finishing
6303 |
7861 |
32556 |
CNC Woodworking
325 |
Hand Tools
6429 |
Jigs & Fixtures
1787 |
Wood & Lumber
7245 |
1614 |
Focus on the Workspace
2618 |
1267 |
Woodworking Trade & Swap
5396 |
LumberJocks.com Site Feedback
2394 |
Coffee Lounge
9630 |
