Forum topic by Bstrom | posted 11-09-2020 05:59 PM | 742 views | 1 time favorited | 11 replies | ![]() |
This will be a report in progress – I just ordered the Grizzly T25554 – Riser Block Kit for $88 to upgrade my 1972 Rockwell/Delta 14” bandsaw. After discussing the column post diameter/shape/dimensions, etc. with the very knowledgeable Grizzly tech support fellow for fit purposes into my saw’s casting , it should work, I feel fairly certain. It will require relocating the riser pins/holes as most of us know. Also bought a Timberwolf 105” x 3/4” x .025” x 3 TPI Thin Bandsaw Blade for $35 as the blade included in the riser kit is simply for setup purposes, not widely understood by some buyers and shouldn’t be a bone of contention in this upgrade kit. So, I’m waiting for the delivery and will report findings. In the end, this upgrade is just $155 and well below the riser kit for Rockwell/Delta’s at $238 – w/o a new blade. Scoring the saw in excellent shape for just $100 and adding this upgrade makes this my best tool investment yet. Can’t wait to slice up some wide boards without ripping them in half. I’ll be back with photos and results… -- Bstrom |
11 replies so far
#1 posted 11-09-2020 06:56 PM |
So, I’m waiting for the delivery and will report findings. In the end, this upgrade is just $155 and well below the riser kit for Rockwell/Delta’s at $238 – w/o a new blade. Where are you finding the OEM Delta riser kit for $238? Cheers, -- Brad in FL - In Dog I trust... everything else is questionable |
#2 posted 11-09-2020 07:07 PM |
eBay and other etailers sell them along with similar Jet riser kits – all cost more than the Grizzly kit. -- Bstrom |
#3 posted 11-09-2020 07:13 PM |
eBay and other etailers sell them along with similar Jet riser kits – all cost more than the Grizzly kit. I’ve seen them for that price, but they are not OEM. BTW: It’s not that I want one – I wouldn’t run a riser on either of mine. It’s just that they haven’t been made for years and finding an OEM kit is like looking for hens teeth – they are very few and far between. Cheers, -- Brad in FL - In Dog I trust... everything else is questionable |
#4 posted 11-09-2020 09:06 PM |
You’re right but these other brands work with the needed mods. The kit I was referring to was a ‘made-for-Delta’ version with no need for the mods. Same parts but ready to install at a higher price. Don’t expect to see a true OEM kit ever again really. Thankfully, my saw cuts very consistent thicknesses so am looking forward to the expanded cut height. -- Bstrom |
#5 posted 11-15-2020 02:11 AM |
Received the kit and had to sort out a difference in my saw – no slots for removing or adding a longer bolt for the riser. It wasn’t an issue after I got my head wrapped around what was needed, so I got started and disassembled the saw. I created new pin location guides with some 3/4” Pine 3/4” hammered down onto the new riser and existing pins in the saw. Positioned them on their respective parts and drilled the pin holes needed on the drill press. Took a little ‘modding’ to make a fit but the metal is an alloy so not too tough to work with. Got the parts ready and reassembly was pretty easy – and accurate enough to get the new blade to run just fine. Although the hardware is intended for a Grizzly saw, I was able to use all the parts they supplied. Also took the time to clean and lube all the adjusters and replace some fasteners with some upgraded hardware. Set up the Timberwolf 3/4” X 3TPI blade (this is one scary looking blade!) and put everything into alignment. The cut is smoother than my recently acquired Wood Slicer as the photo will show. I have a full 12” throat capacity now which is ready to tackle some stock in my shelves. All in all, about a 5 hour job start-to-finish with a very pleasing outcome, not to mention the added value it has provided in this tool. -- Bstrom |
#6 posted 11-17-2020 01:42 AM |
Spent a few hours yesterday resawing some Cedar with the modded saw and had good results. If you hurry it, the saw bogs cutting a full 12” board (including several power strip breaker restarts), but handles a 10” board pretty well. Cut quality is good with the Timberwolf blade – I then planed these boards down to ~1/4” for clock panels. Narrower board widths would probably cut cleaner and be able to sand finish. Like any tool, removing the guard panels and cleaning out the cavities, as well as air spraying the guide assemblies, will be a regular chore each time it is used. Total upgrade cost of the Grizzly riser kit, Timberwolf blade and a little hardware was just $137 – a worthwhile investment. -- Bstrom |
#7 posted 01-26-2021 05:22 PM |
I like your post. I also have a older Rockwell/Delta band saw that I am trying to do this to. I called Grizzly and didn’t get much help. My guide post is a 7/8 hex post, and they told me they didn’t make a hex post anymore. The kit you used is a round post but they couldn’t tell me the diameter of the one in your kit. I think I can make one work i it is 7/8 diameter and has a flat side. Thanks for any help you can give me. |
#8 posted 01-26-2021 10:14 PM |
As you can see, the parts work in spite of their different shapes and sizes. My saw performs great with that kit installed. I also installed their fence for 14” Bandsaws today and it is pretty decent as an alternative to the OEM fence. Had to do some hardware swapping to mount it – I’ll be writing a review here in a bit on a separate post. c -- Bstrom |
#9 posted 01-26-2021 10:35 PM |
I also have the Delta and did mine some yrs back with the Grizzly kit. The fence is the Grizzly also for the 14” ? I have got to check that out!!!!! Have a part # for the fence? Thanks in advance! -- Mike,North Carolina |
#10 posted 01-26-2021 10:52 PM |
Grizzly H7587 Resaw Fence Complete $204 shipped direct from Grizzly you can also get just the fence for about $25 cheaper so be sure to get the Complete kit for the conversion. -- Bstrom |
#11 posted 01-26-2021 11:46 PM |
Thanks for you help ordering my kit now |
Forum | Topics |
Woodworking Skill Share
13201 |
Woodturning
2814 |
Woodcarving
569 |
Scrollsawing
416 |
Joinery
1893 |
Finishing
6347 |
7909 |
32769 |
CNC Woodworking
330 |
Hand Tools
6453 |
Jigs & Fixtures
1804 |
Wood & Lumber
7277 |
1633 |
Focus on the Workspace
2635 |
1272 |
Woodworking Trade & Swap
5418 |
LumberJocks.com Site Feedback
2396 |
Coffee Lounge
9660 |
