Drill Chuck Extension for Sanding Tools
Forum topic by Sumdume posted 11-09-2020 03:46 AM 365 views 0 times favorited 6 replies Add to Favorites Watch
View Sumdume's profile
Sumdume
97 posts in 3850 days
11-09-2020 03:46 AM
Topic tags/keywords: drill extension tool sanding
Hello, I am looking for an extension to hold sanding tools with a round shank. I use the tools to sand bowls I have made with a router. The sanding tools I use are short and it is often difficult to reach deeper areas.
I am not able to purchase a system like the Guinevere sanding system.
EDIT- The tools are mostly about 1/4 inch. Some are about 3/8 inch.
-- Rule # 1 - Don't mix yer blood and sawdust!
View SMP's profile
SMP
3460 posts in 921 days
#1 posted 11-09-2020 03:51 AM
Whats the diameter of the shank? Thats important
Sumdume
#2 posted 11-09-2020 04:15 AM
The diameter varies. Most are about 1/4 inch. Some are 3/8 inch.
View SMP's profile
SMP
#3 posted 11-09-2020 04:37 AM
I have a 6” and 12” version of these. Careful not to get the ones designed for hex, but get it for round, then you can get a 1/4 shank in and tighten up the allen bolts.
https://www.amazon.com/Irwin-88702-6-Extension-Bit/dp/B00004YO9Y
View John Smith's profile
John Smith
2867 posts in 1178 days
#4 posted 11-09-2020 12:45 PM
if you are going to be doing a lot of these projects,
I would look into a flex-shaft that would suit your projects (and budget).
Harbor Freight is $50 and the better name brands up to $400.
pay attention to the handpiece – some do not have the 1/4” shank capacity.
much easier to control than a small wheel on a long shaft in a hand drill.
-- there is no educational alternative to having a front row seat in the School of Hard Knocks. --
Sumdume
#5 posted 11-10-2020 02:00 AM
Thank you SMP. It looks like what I was wanting.
Sumdume
#6 posted 11-10-2020 02:05 AM
John Smith thanks. I will see what I can find. We have a HF locally.
