Minwax polyshade on maple
Forum topic by Airspeed posted 10-30-2020 11:32 PM 924 views 0 times favorited 30 replies Add to Favorites Watch
View Airspeed's profile
Airspeed
471 posts in 3186 days
10-30-2020 11:32 PM
I’m building a custom fishing pole display for a customer, originally she wanted it just clear coated so I used some maple, now she wants it stained and I’ve never had any luck staining maple, thinking of trying Minwax poly shade thinking it will color evenly without a blotchy finish. Have any of you tried this stuff? She wants it fairly dark.
-- http://smg.photobucket.com/albums/v655/aaronhero/
30 replies so far
View johnstoneb's profile
johnstoneb
3183 posts in 3456 days
#1 posted 10-30-2020 11:52 PM
I used minwax poly shade once. Never again. It never dried. I will never use it again. I am not a fan of other minwax finishes I have used them. I have used them had application problems sometimes not always happy with the finish quality.
-- Bruce, Boise, ID
View corelz125's profile
corelz125
3878 posts in 2260 days
#2 posted 10-30-2020 11:54 PM
Stay far away from that stuff it’s horrible. I used it once because that was the only thing in the store for the color I needed after I was done I threw the rest in the garbage.
View CWWoodworking's profile
CWWoodworking
2295 posts in 1463 days
#3 posted 10-30-2020 11:59 PM
To get even really dark maple, you might try a dye stain. Transtint has a black. Read up on how to use dye stains. Different than wipe on, wipe off.
View AlaskaGuy's profile
AlaskaGuy
6774 posts in 3593 days
#4 posted 10-31-2020 12:24 AM
Wood Magazine gives polyshades 2 out of 5. I have used it and giving it 2 points is generous.
https://www.woodmagazine.com/review/finishes/stain/minwax-polyshades-stain-and-finish
View sansoo22's profile
sansoo22
1879 posts in 938 days
#5 posted 10-31-2020 12:47 AM
- AlaskaGuy
The 2 points is a Basketball reference for the 2 points you get for tossing it in the trash.
View CaptainKlutz's profile
CaptainKlutz
5023 posts in 2778 days
#6 posted 10-31-2020 01:39 AM
Death to Polyshades! NEGATIVE 5 STARS!
What dark color, black, brown, blue, red, etc?
Am big fan of Mohawk Ultra Pentrating Dye Stains to color wood:
https://www.mohawk-finishing.com/products/wood-staining-finishing/stains-glazes-colorants/ultra-penetrating-ngr-stain/
Woodcraft recently stopped carrying the Behlen’s dye stain (which is same stuff, from same factory) and now carries the Mohawk brand: https://www.woodcraft.com/categories/stains?brand%5B%5D=Mohawk
This are non-grain raising dye stain using acetone/alcohol solvents. Easy to adjust color with clean rag using solvent blend only. With low RH in Arizona, have to add some glycol as retarder or more solvent. Can lighten color with solvent to make it easier to sneak up final color. Works best as spray and rub down method, or wipe on stain to reduce effects of grain figure blotch with need for blotch control. Like all stains, flooding the surface on figured woods can create blotching.
my second choice is similar dye stain using Transtint liquid colors and 50/50 blend of alcohol/acetone.
If you think it will blotch, be safe: brush on light coating of 1lb cut of blonde shellac, and sand it smooth. 2 coats on end grain you don’t want to be dark.
Best Luck.
-- If it wasn't for bad luck, I wouldn't have no luck at all, Doom, despair, agony on me… - Albert King - Born Under a Bad Sign released 1967
View pottz's profile
pottz
21304 posts in 2268 days
#7 posted 10-31-2020 03:25 AM
i agree with all stay away from minwax polyshades products,look at general finishes or mohawk products if you want quality.
View SMP's profile
SMP
4954 posts in 1189 days
#8 posted 10-31-2020 03:37 AM
I tried it once, tried on a test piece, 1, 2, and 3 coats. Tossed it in the trash. And I’m not even one of the Minwax haters. I often use their Antique Oil Finish.
I also would do dye on maple.
View Rich's profile
Rich
7561 posts in 1873 days
#9 posted 10-31-2020 03:55 AM
If you think it will blotch, be safe: brush on light coating of 1lb cut of blonde shellac, and sand it smooth. 2 coats on end grain you don t want to be dark.
- CaptainKlutz
LOL, yeah. It’s time to burn Polyshades at the stake.
The bottom line is that maple WILL blotch. +1 for the shellac method. Another is a simple glue sizing. You can make it yourself for pennies using Elmers or any other white glue mixed around 1:6 with water. Brush it on liberally, wipe off any puddles and let it dry. It will raise the grain, so knock that off with some 320 grit. Be sure to do a test board, because one application of the sizing might not be enough, and you don’t want to find that out on the final product.
I had a local contractor pay me almost $1000 for some maple raised panel doors. I gave him some spare pieces and detailed directions on blotch control (I even threw in a jar of the glue sizing), test boards and the rest. He called me a week later to make a new set. When I saw the results he brought to the shop from his attempt a staining, it was horrid. But hey, more money for me. Still it was sad to see the doors ruined.
woodbutcherbynight
10506 posts in 3693 days
#10 posted 10-31-2020 04:08 AM
If all the above comments were not enough to sway your decision let me be blunt. Why not just use motor oil? You would get better results and it’s cheaper. Use the glue sizing method or the shellac method or try Transtint or Mowhawk. Much better results and a world less frustration.
- sansoo22
View JAAune's profile
JAAune
2056 posts in 3600 days
#11 posted 10-31-2020 04:19 AM
Polyshades is basically a toner but a slow-drying polyurethane is a difficult base to work with for a toner. Toners are best applied in very thin, even coats to control the amount of color. Fast drying finishes like shellac or lacquer are better for toners since multiple coats can be applied in a short period.
It’s also very difficult to apply toners without a spray gun. I’ve done it by wiping on very thin coats but the results are not as good as a sprayed toner.
Maple will take a dark stain. The easiest way to do so is to spray a dye stain to get close. When that is dry, spray an oil-based wiping stain to complete the color. It takes practice to get it right so testing on sample boards is a necessity.
-- See my work at http://altaredesign.com
View paulLumberJock's profile
paulLumberJock
77 posts in 482 days
#12 posted 10-31-2020 05:18 AM
I have made a bunch of stuff in maple.
The finish that looks best in my opinion is, clear shellac then a gel stain then poly.
The thing is, the gel stain will not give it a lot of color, at least not the kind I used. It
will slightly darken it, but if you have some maple that’s really white, it doesn’t do much at all.
However, if it’s already got poly on it, you can put some gel stain over the poly, (sand the poly first, then
gel stain, then another coat of poly).. that will add some color. I have done it to try to even out some pieces. not ideal, but probably better than polyshades.
If you have not put poly on yet and she wants it darkened, you probably need an oil based stain, but yea, unlike
a gel stain, it might blotch, but I used some really red oil based stain once on maple (darker than I thought it would be).. It was pretty even color, but a bit too dark for me.
Good luck on you project, I am not a finishing expert, just a hobbyist.
View Rich's profile
Rich
#13 posted 10-31-2020 05:25 AM
- woodbutcherbynight
30 weight? Or should I use something like 5W-40 to account for temperature swings?
woodbutcherbynight
#14 posted 10-31-2020 05:29 AM
- Rich
I recommend high mileage well burnt up diesel oil. For that deep rich color.
AlaskaGuy
#15 posted 10-31-2020 05:36 AM
- Rich
5w-20 would be plenty good around here.
showing 1 through 15 of 30 replies
