any tips on how to carve this texture
« back to Woodcarving forum
Forum topic by harum posted 10-28-2020 07:09 PM 538 views 0 times favorited 14 replies Add to Favorites Watch
View harum's profile
harum
410 posts in 2556 days
10-28-2020 07:09 PM
Topic tags/keywords: question
This is a photo from a Bosnian woodworking shop, Zanat Studiolise(?), famous for traditional handmade designs.
Do I understand this correctly that the texture as in the photo can be made with a back bevel gouge? What sweep, if yes?
Would appreciate any tips and comments.
Thank you and Best Wishes,
H.
-- "If you're not counting the ripples when throwing pebbles in the water, you're wasting your time."
14 replies so far
View Rich's profile
Rich
6145 posts in 1503 days
#1 posted 10-28-2020 08:10 PM
Yep, that’s how it’s done. No magic there, just pare away. That gouge looks like maybe a 7 sweep, give or take. I doubt it’s critical, just what looks good to you and whatever you might have in your carving tool collection
View SMP's profile
SMP
2858 posts in 819 days
#2 posted 10-28-2020 08:35 PM
Kind of looks to me like possibly a couple sizes sweeps? Like for example a beginner set may come with a #3, 5, and 7 gouge. Use the #3 or 5 to make a shallow then use the 7 to make the little scallops. Just a guess.
View Aj2's profile
Aj2
3495 posts in 2711 days
#3 posted 10-29-2020 02:05 AM
All gouges will leave a cut like that.
The real test is can you get a gouge sharp enough to cut across the grain ??
-- Aj
View Rich's profile
Rich
#4 posted 10-29-2020 02:31 AM
- Aj2
No, not all gouges will make those.cuts. A #1 is flat, and the curve increases as the numbers do. For example, here are #4 profiles:
Here’s a #7:
View Aj2's profile
Aj2
#5 posted 10-29-2020 04:44 AM
I would like to change my answer to all no 7 gouges will make a texture similar to that.
If the craftsman can sharpen his or her tool.
I offer this example that I introduced to the end grain of a kitchen cart made from hickory.
Thanks Rich :)
Good Luck
-- Aj
View Rich's profile
Rich
#6 posted 10-29-2020 04:57 AM
- Aj2
Change made, Aj. And yeah, keep ‘em sharp.
harum
#7 posted 10-29-2020 05:53 AM
Rich, SMP, Aj, Thank you for all the tips! Will start with No. 7 then. Yes, getting and keeping the gouge sharp enough to use it without a mallet is something to learn. The guy in the video doesn’t seem to be rotating the board or using mallet, creates scallops in one motion. Either his gouge is super-sharp, or the wood is relatively soft.
Nice cart Aj! What’s the finish?
View John Smith's profile
John Smith
2776 posts in 1076 days
#8 posted 10-29-2020 12:29 PM
there is a member here that used this technique recently in a fireplace mantle for his home. although he used an assortment of hand and power tools, it still looks good.
and his completed project: https://www.lumberjocks.com/topics/311406
what are you going to carve for your project ??
-- there is no educational alternative to having a front row seat in the School of Hard Knocks. --
harum
#9 posted 10-29-2020 01:26 PM
Thank you, John! Interesting thread. I want to give some texture to plain and boring cabinet doors.
John Smith
#10 posted 10-29-2020 01:28 PM
- Aj2
AJ – did you do anything to the endgrain of the table? any carving ?
I’m trying to understand your post and the No. 7 gouges.
harum
#11 posted 10-29-2020 02:29 PM
On the other hand, there’s also a ball gouge attachment to an angle grinder, which YouTube has just suggested. Probably, doesn’t leave as smooth a surface as a sharp gouge.
View Lazyman's profile
Lazyman
5943 posts in 2301 days
#12 posted 10-29-2020 02:54 PM
I have a ball gouge for the angle grinder and it can leave a similar surface but it is more difficult to control so you may not get the exact same effect as the picture. I find it more useful for hollowing or scooping out a depression than for surfacing.
View Phil32's profile
Phil32
1180 posts in 817 days
#13 posted 10-29-2020 11:47 PM
Yes, it is a random pattern of gouge “scoops” – probably #7
-- Phil Allin - There are mountain climbers and people who talk about climbing mountains. The climbers have "selfies" at the summit!
Phil32
#14 posted 11-02-2020 06:25 PM
It should also be noted that in the original photo the scoops are being made cross-grain with a very sharp gouge. The cut is a very small shaving. There are many woods that would not work well for this, even with a sharp tool.
