Joint Design
« back to Joinery forum
Forum topic by Zach117 posted 10-28-2020 02:08 AM 528 views 0 times favorited 22 replies Add to Favorites Watch
View Zach117's profile
Zach117
26 posts in 3973 days
10-28-2020 02:08 AM
I need suggestions on a joint design for the piece below. Dimensions will be 34 inches long by 11 inches wide by 1 3/4 inches thick. I don’t see how I can make the design out of a single piece of wood. Mainly, I cant figure out how to cut the interior radius on the bottom for an 34” x 11” wide board.
My thinking is to make it three pieces seen in the second picture. A flat 3/4” board attached to each 1.75” end piece. The easiest way I can think of is to attach end grain to end grain and use a floating tenon such as beadlock. Cut the 11” width into three pieces as well to be wide enough to fit three floating tenons and glue the middle one only similar to a breadboard end style. My only other thought was a half lap joint, but I would like to avoid the “Z” shape of the joint on the front. Looking for it to be more seamless looking.
Any thoughts on an easier or better joint?
22 replies so far
View therealSteveN's profile
therealSteveN
6628 posts in 1487 days
#1 posted 10-28-2020 03:33 AM
It looks to be something that would favor either a dowel at the lower end, or a Domino at the upper, with the Domino being the quicker, and easier of the 2. There are actually several available systems to make a dowel like join. I don’t have any of them, but have seen Beadlock, I’ve seen others, but can’t recall names for them.
Your issue as you have already stated is end grain, so something to cross is needed for strength, and glue surface where it won’t just get sucked up in the end grain. All of the above are the invisible joints. It’s possible to box, or Dovetail I suppose, but that sort of squashes seamless, unless you would want to turn it into a feature.
Router joints like a lock miter are generally going to be more for pieces at right angles, yours is really a straight line join, but a lot of folks set up their Lock Miters flat to check for fit, in that attitude they do offer a lot more glue surface, but they are going to be fussier than dowels, or Dominos. Plus with the lock miter it would either be seen from the edges, or require more work to hide it.
Sitting looking at your pics. I don’t think I’d sweat the join, it’s the glue up I wouldn’t want to mess with. Thinking you might need to make a jig. Something to take the curve you are introducing, out of play. Chairmakers probably figure that out in short order though. They are all the time clamping parts that have no business being together, and making it look easy.
-- Think safe, be safe
View SMP's profile
SMP
2853 posts in 818 days
#2 posted 10-28-2020 03:47 AM
Personally i would change it so the top goes all the way across and has rounded ends, and the little “feet” are glued to the bottom side of the top piece and then curved as needed to match up to the top.
View Aj2's profile
Aj2
3495 posts in 2710 days
#3 posted 10-28-2020 03:49 AM
I think your asking for trouble with the three piece design. All those joints with wide short grain pieces too much room for error.
Even the whole one piece design has its challenges. That’s the road I’d take.
Good Luck
-- Aj
View Rich's profile (online now)
Rich
6142 posts in 1502 days
#4 posted 10-28-2020 04:12 AM
- therealSteveN
Domino? Perhaps the OP doesn’t own one (I didn’t see a reference to it in the post), and does not care to spend the $1000 to buy one.
This one’s a no-brainer. Instead of trying to join the pieces as you have shown, mill and glue the piece to the underside of the shelf. That way you’ve got long-grain and it will hold just fine. Also, the joint will be less visible on the edge grain that it would on the surface.
therealSteveN
#5 posted 10-28-2020 04:31 AM
- therealSteveN
Dowel
Also usually very low cost.
Kindly get off my back.
Rich
#6 posted 10-28-2020 04:54 AM
- therealSteveN
Dowel
- therealSteveN
I think we all know what a dowel is. The Festool Domino is an awesome tool, but costs $1000.
If a drawing is needed, I’ll provide one, but it’s no different than gluing edging strips under a shelf to make a 3/4” edge appear to be 1 1/2”, except that this one has profiles milled before attaching.
Rich
#7 posted 10-28-2020 04:57 AM
Back to the OP, you could do a cove cut on a strip of wood (cross grain, so it matches the end grain of the shelf), glue it to the underside of the shelf, and then do a round over cut along the top edge to complete the profile. Let me know if you’d like more detail, and I’ll be happy to provide you with a sketch.
The major advantage of adding moulding to the underside of the shelf is that it’s parallel grain, so no dowels or $1000 dominos are needed.
View Madmark2's profile
Madmark2
1809 posts in 1501 days
#8 posted 10-28-2020 05:08 AM
Spline it.
-- The hump with the stump and the pump!
Rich
#9 posted 10-28-2020 05:31 AM
No one seems to be able to get away from the end-grain joint. Don’t do it that way.
A cove cut on a strip, glued to the underside of the shelf, and the shelf edge then rounded over will give you the profile you want.
View Bstrom's profile
Bstrom
205 posts in 86 days
#10 posted 10-28-2020 11:32 AM
No one seems to be able to get away from the end-grain joint. Don t do it that way.
- Rich
SMP and Rich seem to have this figured out well – for strength and appearance.
-- Bstrom
View ibewjon's profile
ibewjon
2136 posts in 3706 days
#11 posted 10-28-2020 01:34 PM
+1 for Rich and SMP. Don’t make it harder than it needs to be.
View LeeRoyMan's profile
LeeRoyMan
1443 posts in 639 days
#12 posted 10-28-2020 01:52 PM
No Joints….....Use 8/4,
rout your 2 coves first,
then use a dado blade and remove the rest of the middle area.
View AndyJ1s's profile
AndyJ1s
471 posts in 668 days
#13 posted 10-28-2020 04:51 PM
I agree that if you want to do each end in two parts, the long-grain to long-grain joint will be far stronger, and the seam on the outside will be down on the curve and therefore less visible.
But there are ways to do this in one piece, by cutting the coves on the router table, or a table saw.
Fine Woodworking had a very good, detailed article on the setup and technique. It even went into setups for tilting the saw blade for asymmetrical coves.
The rest could be done on a slab flattening jig, or hogged out with a dado blade or a dado/mortise bit in a router table.
But all this begs the question: what is this piece for, and how will it be joined to apparent other pieces in the project? That may impact the choice of an optimal solution.
-- Andy - Arlington TX
Zach117
#14 posted 10-28-2020 05:32 PM
Thanks for the advice everyone! It seems that this method might be easiest. Didn’t think of it. For the bottom piece, cut the interior curve using a cove bit on the router table and then use a round over bit “freehand” for the outside curve at the top?
This is indeed a shelf. It will be the top shelf for a bookcase. There will be four tenons, end grain, going into the four corners of the bottom of this shelf where mortises will be cut.
View DS's profile
DS
3590 posts in 3333 days
#15 posted 10-28-2020 05:34 PM
+1 to LeeRoyMan’s suggestion to use 8/4
I might make this in longways rips, cut the rough profile on the bandsaw, route to final size with a template and flush trim bit in my router table, then glue them together to get my overall width.
(What I would actually do is write a program for the CNC to cut it with the 3” long, 5/8” diameter low helix bit, out of the 8/4 board, making half a dozen identical pieces in as many minutes, then just glue them up and sand it. But, you might not have access to that tech, so…)
- LeeRoyMan
