Hanging File Drawers
Forum topic by 1thumb posted 10-26-2020 04:12 PM 302 views 0 times favorited 8 replies Add to Favorites Watch
View 1thumb's profile
1thumb
186 posts in 3070 days
10-26-2020 04:12 PM
They’ll be 22” deep with enough width for 3 rows of files w/6 hanging bars, looking like approx 40”. 1/2” ply, Heavy duty slides, cut grooves, drop a piece of aluminum for hang rod and call it done. No big deal right?
8 replies so far
6558 posts in 3407 days
#1 posted 10-26-2020 04:51 PM
Be sure to make them deep enough that you have clearance for those little plastic tabs on the top of the file folders (don’t ask).
View SMP's profile
SMP
2859 posts in 819 days
#2 posted 10-26-2020 04:57 PM
Be sure to make them deep enough that you have clearance for those little plastic tabs on the top of the file folders (don t ask).
- Fred Hargis
Haha! I know exactly what you mean! I made some and forgot about that. Even though I left some default clearance it now sounds like the old “playing card in the bicycle spokes” when opening and closing the drawer.
1thumb
#3 posted 10-26-2020 05:13 PM
- Fred Hargis
Thanks. I won’t ask
View SMP's profile
SMP
#4 posted 10-26-2020 05:22 PM
- Fred Hargis
Thanks. I won t ask
- 1thumb
Also since you say 3 rows wide, make sure to leave enough space between for the metal hooks on whatever folders you get. Some brands have a loose hook bar that can slide over, some are attached. You are going to want around 1” between each frame.
View Madmark2's profile
Madmark2
1813 posts in 1502 days
#5 posted 10-27-2020 02:24 AM
Be sure to counterweight or attach it to the wall to keep it from tipping.
-- The hump with the stump and the pump!
View LesB's profile
LesB
2664 posts in 4357 days
#6 posted 10-27-2020 05:05 PM
I have done that on single wide drawers and it works fine. I used 1/8” x 1/2” aluminum bar.
Doing so on a drawer wide enough for 3 rows is going to make the drawer heavy so make sure you have drawer slides that will support the weight and they should be full extension type. As Madmark said, beware of it tipping over when open.
-- Les B, Oregon
View stevejack's profile
stevejack
191 posts in 234 days
#7 posted 10-27-2020 06:25 PM
DOnt forget a lot of drawer slides have tabs on them so you bend so you can correct slight errors in alignment.
View EarlS's profile
EarlS
4077 posts in 3262 days
#8 posted 10-27-2020 10:39 PM
Speaking from past experience, I’d suggest buying the hangers first and doing a mock up of the drawer just to confirm everything. Otherwise you might have a drawer that isn’t quite the right size for the hanging folders and you wind up sort of stacking them in a sort of diagonal heap….. did I tell you I’m speaking from experience? Just wanted to be sure.
