Epoxy recommendations please
Forum topic by BlueRidgeDog posted 10-24-2020 02:15 PM 246 views 0 times favorited 5 replies Add to Favorites Watch
View BlueRidgeDog's profile
BlueRidgeDog
739 posts in 691 days
10-24-2020 02:15 PM
Well I cut some tenons wrong on a table (front and side rails that connect to the legs). I gauged the cut off of a slightly thicker rail and the side rails now have a tenon that is too thin and is very sloppy in the mortise. I don’t have enough lumber to remade the rails.
I will use epoxy and micro balloons to glue the joint.
However, when looking for epoxy now, everything is about “clear” and “pouring”.
What epoxy do you use for joints? I have my usual 5 minute stuff and 60 minute stuff that I would normally use, but I need to buy a bit more as these joints are large.
Thanks for your brand recommendation. Again, looking for joint strength not clarity.
5 replies so far
BlueRidgeDog
#1 posted 10-24-2020 02:17 PM
View shipwright's profile
shipwright
8618 posts in 3709 days
#2 posted 10-24-2020 02:23 PM
There are lots of good bonding epoxies but don’t expect micro balloons to thicken it. They are a filler, not a thickener. My favourite thickener is Mini Fibers from FiberTek.
https://fibertek.ca/shop/fiberglass-materials/fillers/mini-fibers/
MrUnix
8277 posts in 3110 days
#3 posted 10-24-2020 03:18 PM
I was going to suggest the same as Paul. Baloons are good for fairing and filling where sanding will be required. But for gap filling, fibers are recommended – like what Paul mentions, or #403 Microfibers from West System.
As far as which epoxy… I’d just get whatever you happen to have available locally. I use West System as my main structural epoxy, Alumilite for wood repair and hole filling, and a couple of those syringe types that I use when a strong adhesive is needed. In your case, any of them would work just fine.
BlueRidgeDog
#4 posted 10-24-2020 03:55 PM
Excellent…I will use the fibers. Anyone know of a US distributor for Fiber-Tek?
View WoodenDreams's profile
WoodenDreams
1177 posts in 822 days
#5 posted 10-24-2020 08:40 PM
You may want to use wood shavings from a hand plane as a filler with glue or epoxy. Here’s a 3 minute video on repairing loose tenons. I feel this way is stronger vs using just epoxy. https://www.wwgoa.com/video/tightening-loose-tenons-013562/
