Veneer question
Forum topic by Andybb posted 10-22-2020 07:11 PM 327 views 0 times favorited 15 replies Add to Favorites Watch
View Andybb's profile
Andybb
2934 posts in 1516 days
10-22-2020 07:11 PM
Topic tags/keywords: veneering
Sadly, I’m getting ready to build yet another cremation container, this time for my best friend’s wife.
For this one, I have decided to use some really nice looking redwood burl from Woodcraft and affix it to MDF for a 4 corner match. Don’t have a lot of it to waste so I thought I’d ask for techniques suggestions.
I plan to put splines in the corners. Should I attach the veneer to the MDF before I cut the mitered corners or after? I bought a new, sharp 80 tooth thin kerf blade for the task. I just don’t want ragged edges or chance that the MDF would show on the corners. Figured I’d edge the MDF with a dark brown marker before assembly.
Ideas?? Suggestions??
Thanks in advance.
-- Andy - Seattle USA
15 replies so far
View jmartel's profile
jmartel
9106 posts in 3063 days
#1 posted 10-22-2020 07:16 PM
After. Glue it on, then trim it up with a knife carefully.
Andybb
#2 posted 10-22-2020 07:20 PM
- jmartel
That was my original thought but I want to make sure the miter angle carries through the veneer as well even though it’s really thin. But, I agree with the “after” idea cuz once it’s stuck, it’s stuck and can’t be undone without spending another $50 for another pack of the veneer.
View Jim Jakosh's profile
Jim Jakosh
25468 posts in 4018 days
#3 posted 10-22-2020 07:28 PM
It has to be after if you want the splines to show. If you cut them first, the veneer will cover them up. Make sure it is glued very well and you should not have a problem cutting the spline slots.
Jim
Andybb
#4 posted 10-22-2020 08:24 PM
Jim
- Jim Jakosh
Yes. Probably did a poor job of explaining that. The splines will go into the finished box last and carefully flushed regardless of which order I apply and cut the veneer.
jmartel
#5 posted 10-22-2020 09:05 PM
Worst case scenario, if you do end up blowing it out, you could put a 1/4” border around it with a dado blade and some solid contrasting material.
View Lazyman's profile
Lazyman
5932 posts in 2300 days
#6 posted 10-22-2020 09:09 PM
I assume you are using a table saw spline jig? One thing to be careful of is getting tear out on the veneer as you cut the splines Some masking tape and a zero clearance backer board should help.
View Loren's profile
10784 posts in 4561 days
#7 posted 10-22-2020 09:12 PM
Do a test with cheap veneer to see if your idea is likely to work for the result you want. That’s my suggestion.
View splintergroup's profile
splintergroup
4121 posts in 2135 days
#8 posted 10-22-2020 09:58 PM
I haven’t had any issues cutting burl veneerer panels on a table saw when the veneer is “up” and the cut line is taped. That being said, it is also straight forward to veneer an already assembled box, being careful when trimming off the excess at the edges.
Be aware that most all burls have tiny holes that will seep glue when pressing. I use a double layer of paper towels against the veneer. It won’t stop the seepage, but does a wonderful job of “sucking up” the excess glue versus having a caul or other impermeable layer against the veneer which will allow the squeeze out to spread (difficult to remedy at that point)
Andybb
#9 posted 10-22-2020 10:00 PM
- jmartel
- Lazyman
Do a test with cheap veneer to see if your idea is likely to work for the result you want. That s my suggestion.
- Loren
Yes, yes, and yes. All were in the back of my head. I have enough regular old veneer and MDF to build a “prototype” to develop the technique first. Thanks.
View shipwright's profile
shipwright
8618 posts in 3711 days
#10 posted 10-22-2020 11:51 PM
You can always cut your mitres a little big and finish with a disc or belt sander (stationary).
View SMP's profile
SMP
2856 posts in 818 days
#11 posted 10-23-2020 01:02 AM
What are you using for the splines? I use a full kerf blade so i can just use 1/8 stock as splines. I find its less work.
Andybb
#12 posted 10-23-2020 01:08 AM
I haven t had any issues cutting burl veneerer panels on a table saw when the veneer is “up” and the cut line is taped. That being said, it is also straight forward to veneer an already assembled box, being careful when trimming off the excess at the edges.
Be aware that most all burls have tiny holes that will seep glue when pressing. I use a double layer of paper towels against the veneer. It won t stop the seepage, but does a wonderful job of “sucking up” the excess glue versus having a caul or other impermeable layer against the veneer which will allow the squeeze out to spread (difficult to remedy at that point)
- splintergroup
Good call about the squeeze thru on the burl. I was thinking about that. I’ve got TB I, II and III, TB Hide Glue and Titebond Translucent. Any recommendations?
Andybb
#13 posted 10-23-2020 01:11 AM
- SMP
Right you are. I’m using a flat top full kerf 1/8” blade. It’s just easier.
View Robert's profile
Robert
4134 posts in 2393 days
#14 posted 10-23-2020 09:56 AM
- jmartel
I recommend doing this anyway. Not a good idea to have exposed corners.
But to answer your question, there are several ways address the issue, my thinking it veneer first, cut miter just a bit short, make a jig, and either plane or sand (sanding probably safest).
A jig such as donkey ear attachment to a shooing board is a good idea. I just made one because I’m planning to build a bunch of veneer boxes for Christmas presents.
You may already know, but if the burl has any small gaps or holes, I would use hide glue. PVA glue will ruin your project.
Andybb
#15 posted 10-23-2020 02:45 PM
- Robert
Not sure what is meant by 1/4” boarder using a dado. Any examples of that you can point to?
