Grizzly vs Delta X5 Bandsaw
Forum topic by Thorxes posted 10-22-2020 02:14 PM 274 views 0 times favorited 5 replies Add to Favorites Watch
View Thorxes's profile
Thorxes
18 posts in 42 days
10-22-2020 02:14 PM
Topic tags/keywords: grizzly bandsaw resaw riser fence
Hi Everyone!
I have a predicament.
I recently purchases a near new Grizzly GO555X 14” bandsaw (with fence, no riser, no blades) for $400 via classifieds.
Recently I’ve come across what looks to be a Delta X5 28-475 14” bandsaw (with fence, with riser, with 4-5 blades) for likely $500.
What would you do if you were needing the 12” cutting capacity?
(1) Keep the grizzly, buy blades and a riser kit.
(2) Get the Delta X5 and resell the Grizzly.
Keeping both is not an option – my wife would kill me.
5 replies so far
View ChefHDAN's profile
ChefHDAN
1780 posts in 3762 days
#1 posted 10-22-2020 02:22 PM
Since many of the saws are using the same riser kit essentially, I would first see if the Delta riser would fit the Grizzly. If it fits, I’d get the Delta and take the riser & blades for the Grizzly & sell the Delta.
Thorxes
18 posts in 42 days
#2 posted 10-22-2020 05:35 PM
Since many of the saws are using the same riser kit essentially, I would first see if the Delta riser would fit the Grizzly. If it fits, I d get the Delta and take the riser & blades for the Grizzly & sell the Delta.
- ChefHDAN
Oh good call. Maybe someone here can confirm if the riser is compatible?
Aside from that – do you think $500 is a bit overpriced for the Delta being so old?
View MrUnix's profile
MrUnix
8278 posts in 3112 days
#3 posted 10-22-2020 08:25 PM
AFAIK, the “X5” thing was just a marketing promotion, and the machine itself was no different than a non-X5 version. IIRC, they did the “X5” promotion sometime around 2003, where they gave you a 5 year warranty (normally 2), a ‘savings book’ of coupons for other purchases, choice of a $50 rebate or a free Porter-Cable tool (or free mobile base), and I think they may have also come with an upgraded stock blade, and a few cosmetic differences, but not much more.
Also, having two 1950 versions of that saw, I would not consider that X5 all that old – probably not even broke-in yet!
Thorxes
18 posts in 42 days
#4 posted 10-22-2020 09:03 PM
Just so you know, the “X5” thing was just a marketing promotion, and the machine itself was no different than a non-X5 version. IIRC, they did the “X5” promotion sometime around 2003, where they gave you a 5 year warranty (was 2), a savings book of coupons for other purchases, choice of a rebate or a free Porter-Cable tool (or free mobile base), and I think they may have also come with an upgraded stock blade, and a few cosmetic differences, but not much more.
- MrUnix
I appreciate the info.
Does $500 seem about right then? In my research I’ve found a few threads stating that it’s actually a bit high on price point, and this was for threads about 5 years old.
Thorxes
18 posts in 42 days
#5 posted 10-23-2020 04:34 PM
Update: I think I found the same Delta saw for about $200 on craigslist. I think I’ll go with that one.
