murphy bed platform floppy
« back to Joinery forum
Forum topic by infectiousintegrity posted 10-20-2020 09:44 AM 299 views 0 times favorited 5 replies Add to Favorites Watch
View infectiousintegrity's profile
infectiousintegrity
1 post in 39 days
10-20-2020 09:44 AM
Ok Lumnberjocks…I need help I made a Murphy bed but I can’t seem to get the frame to move fluidly. I have two corner brackets on each end and it’s still.floppy…..i pick one corner up and the whole thing twists…I’m not putting hydraulics on it until I figure out whyit’s doing this…aHhh
thanks ahead of time…
[email protected]
5 replies so far
View Loren's profile
10788 posts in 4563 days
#1 posted 10-20-2020 03:56 PM
I think you’ll need to be a lot more specific to have a chance at somebody here understanding the problem well enough to provide a solution.
It sounds like you have a hardware problem, but maybe you have a woodworking problem. You might try contacting the manufacturer of your hardware kit.
View Sycamoray's profile
Sycamoray
26 posts in 156 days
#2 posted 10-20-2020 03:56 PM
A few questions:
How much does it twist? Even high-end commercial murphy beds have some deflection if you raise it from one corner only. In fact, many manufacturers explicitly state that you should only raise or lower from the centerline.
Did you follow a set of plans?
What size components are you using?
Are the corner brackets the only joinery?
View sras's profile
sras
5650 posts in 4045 days
#3 posted 10-20-2020 06:33 PM
Are you working with a bare frame or is there a wall panel attached?
View DS's profile
DS
3590 posts in 3336 days
#4 posted 10-20-2020 07:26 PM
There is a reason the frame is usually metal
https://www.murphybeds.com/ShopHardware
View northwoodsman's profile
northwoodsman
413 posts in 4662 days
#5 posted 10-20-2020 07:53 PM
It reminds my of a technique that a furniture salesman showed my once. If you pick up a couch, chair or table by one corner and the closest leg follows suit, buy it. If it sags or bends keep looking. In your case it sounds like joinery techniques, material choices, or weight. The hydraulics should help considerably as they will act as an assist for the sagging corner. I agree that you should lift it up closely to the centerpoint.
-- NorthWoodsMan
