Fascia and sub-nailer
Forum topic by ed23 posted 10-18-2020 12:19 AM 272 views 0 times favorited 8 replies Add to Favorites Watch
View ed23's profile
ed23
60 posts in 117 days
10-18-2020 12:19 AM
I need to replace the 1×6 fascia which happens to have a 1x ontop to kick the drip edge out but I noticed that the subnailer at the end is rotted. I dont want to remove the soffit, drip edge, etc, so I was wondering if I could use wood epoxy and build up the corner after using that green water proofing paint. The other piece(missing in pic) will be new with a nice 45 corner. Problem is people toenail the corners and it causes many issues.
Are there any tricks to cut and replace fascia boards in place. I was thinking a long saber saw blade. sawzall blades are too wide.
8 replies so far
View SMP's profile (online now)
SMP
2678 posts in 791 days
#1 posted 10-18-2020 12:45 AM
I usually use a combo of a sawzall and multi-tool with various wood blades.
View ed23's profile
ed23
#2 posted 10-18-2020 12:48 AM
What type of multi-tool?
View pottz's profile
pottz
11736 posts in 1870 days
#3 posted 10-18-2020 03:00 AM
- ed23
a multi tool is an oscillating tool that uses various blades to make very thin cuts in various materials.many companies make them.
i think what you want to do is only a band aid for cancer,it probably will only prolong what really needs to be done.
SMP
#4 posted 10-18-2020 03:07 AM
- ed23
I have this one, but most tool companies have their own, some cordless . Those blades you can attach at any angle and plunge in.
https://www.amazon.com/Bosch-Power-Tools-Oscillating-Saw/dp/B01ER7J976
View AlaskaGuy's profile
AlaskaGuy
6115 posts in 3195 days
#5 posted 10-18-2020 06:35 AM
What’s a multi too…...........watch a couple of these videos you’ll get the idea
https://www.youtube.com/watch?v=Cxou6yLfTaI
View ed23's profile
ed23
#6 posted 10-18-2020 05:06 PM
That cut on the multi tool is going the wrong way. I can cut the attaching nails with a sawzall, its crosscutting the fascia board in-place thats tricky. I may try a 7” sabre saw blade. Replacing the 2x subnailer would be hell because its attached to the ends of the trusses. Only 2” at the end is bad. If I can get the fascia to seal it should be fine.
View Eric's profile
Eric
572 posts in 759 days
#7 posted 10-18-2020 11:56 PM
You will have to cut back further than you are thinking. 3 – 5 foot to have a good point to secure to. But you will also have to deal with what is behind that, find the source of the water damage, or your efforts will be a waste if your time. And hopefully the roof deck is not affected.
-- Eric, building the dream
View ed23's profile
ed23
#8 posted 10-25-2020 12:39 AM
7” blade in the sabre saw working perfect.
