Forum topic by controlfreak | posted 10-15-2020 04:25 PM | 483 views | 0 times favorited | 2 replies | ![]() |
I am about to glue up my SYS laminated top to my Moravian bench. I had planed to do a mostly hand tool build but after I have used a jointer and planer to get all the boards square I am wanting to get this done quickly so I can start using he bench. I will however attempt the legs and tray going full hand tool though. I am opting to make a router sled to flatten the top and bottom of the bench. I figure I can use the same material for the rails and sled construction. Question: What do you think I should make the sled rails out of? It will need to be about seven feet long. Right now I am leaning toward MDF with three clamping points. I think I will get a monster level to help check flat and level. |
