Stanley Miter Box and weird fasteners - WTH Stanley!
« back to Hand Tools forum
Forum topic by Tony1212 posted 10-13-2020 02:23 PM 738 views 0 times favorited 9 replies Add to Favorites Watch
View Tony1212's profile
Tony1212
580 posts in 2943 days
10-13-2020 02:23 PM
Topic tags/keywords: miter box hand saw stanley
I’m currently refurbing my grandfather’s Stanley 2246 Miter Box. They seemed to have used non-standard fasteners.
The big thumbscrews on the back that hold the metal bars to hold the work against the fence use a 1/4” fastener, but it is not 1/4-20 nor 1/4-28. I didn’t bother checking what the thread count was since I had to drill out a broken bolt a re-tap the hole anyway and I only had one of those two options in my tapping kit.
However, the part that swings to different angles has some holes that are 10-28. Those screws are long gone and I have to find some way attaching the lever.
10-28 is not something you can just hop on down to the local hardware store and find. Well, actually it is. I just had to look in the plumbing section. Apparently some bib screws are 10-28. But since they are for holding handles onto valve stems, they are only 3/8” long.
Neither McMaster-Carr nor Grainger carry anything like that. Any other ideas on where to look for non-standard fasteners for less than $5 apiece? Anyone know of any place that makes custom stuff like this?
-- Tony, SW Chicago Suburbs
9 replies so far
View SMP's profile
SMP
4692 posts in 1114 days
#1 posted 10-13-2020 02:44 PM
Some older cars had 1/4-24 screws. The fillister head type screws. I’ve had to buy some for some classics i’ve restored. Think i even have tap and dies.
View drsurfrat's profile
drsurfrat
968 posts in 395 days
#2 posted 10-13-2020 03:09 PM
Stanley is notorious for non-standard screws. I looked for a long time and found what you did, bib screw for a faucet handle at 10-28. (In my case, a No 78 depth stop). I would have liked to find a longer one with a thumbscrew head – yea, right. At least it worked.
Custom screws will cost you much more thank $5 apiece. There is a seller on eBay that sells single screws for Stanley tools at ridiculous prices.
I think the only chance you have is if you need a bunch, then it might be possible to find a die and cut your own.
I have many extra parts for Stanley planes and tools, so if you (or anyone reading this) needs something, let me see if I can help.
-- Mike (near Boston) ... Laziness is the mother of invention, necessity is the mother of exhaustion - me
View HerbC's profile
HerbC
1820 posts in 4068 days
#3 posted 10-13-2020 06:52 PM
Look at the topic Miter Box of Your Dreams
Lot of expertise there.
-- Herb, Florida - Here's why I close most messages with "Be Careful!" http://lumberjocks.com/HerbC/blog/17090
View HokieKen's profile (online now)
HokieKen
19049 posts in 2347 days
#4 posted 10-13-2020 07:00 PM
How many 10-28 screws do you need? Do you know the length you need and the type of head you need on it? If you know all of that, I can probably turn them for you.
-- I collect hobbies. There is no sense in limiting yourself (Don W) - - - - - - - - Kenny in SW VA
View MrUnix's profile
MrUnix
8744 posts in 3408 days
#5 posted 10-13-2020 07:03 PM
A quick google shows that you can get them by the boatload at Fastanal in all shapes, sizes and material. There are a few other places that turn up as well. Quick look showed a stainless steel 1/4×28 2.5” hex socket bolt at about $0.67 a piece.
View CaptainKlutz's profile
CaptainKlutz
4853 posts in 2703 days
#6 posted 10-13-2020 07:04 PM
+1 Miter box of your Dreams thread.
Don’t play with miter boxes, but Stanley used 12-20 on hand plane handles/frogs.
Looks and feels like 1/4-20, but it is not.
St James Bay use to offer a tap/die set. Was often listed on fleabay.
Cheers!
-- If it wasn't for bad luck, I wouldn't have no luck at all, Doom, despair, agony on me… - Albert King - Born Under a Bad Sign released 1967
Tony1212
#7 posted 10-13-2020 07:07 PM
- HokieKen
I’ll keep that in mind. I bought a bunch of the bibb screws, so I’ll see what I can do with them. If I can’t get them to work, I’ll probably contact you. Thanks.
Tony1212
#8 posted 10-13-2020 07:09 PM
- MrUnix
Those are all 1/4”. Too big for what I need. I thought about drilling the holes out and re-tapping with the next larger “regular” size (12-24 or 12-28).
HokieKen
#9 posted 10-13-2020 07:30 PM
- Tony1212
If you chase those holes with a 12-28 tap, you probably won’t even need to drill them out. That’s your cheapest and easiest solution if you aren’t intent on keeping the box original.
