How to Fumigate Wood?
Forum topic by tool_junkie posted 10-09-2020 01:17 AM 326 views 0 times favorited 7 replies Add to Favorites Watch
View tool_junkie's profile
tool_junkie
331 posts in 3413 days
10-09-2020 01:17 AM
Topic tags/keywords: fumigate fumigation
All,
A few years ago I cut a few “cookies” out of a big Laurel Oak trunk which have been drying outside since. Before I start any project with these cookies, I want to fumigate them to make sure there’s no insects or pests inside them. I don’t have the budget to take them to a kiln or a professional place for this purpose.
Can someone recommend a cost effective way to fumigate? What chemicals to use? etc.
Thanks!
7 replies so far
View Dark_Lightning's profile
Dark_Lightning
4210 posts in 3993 days
#1 posted 10-09-2020 02:24 AM
How big are those “cookies”?
-- Steven.......Random Orbital Nailer
tool_junkie
#2 posted 10-09-2020 05:49 AM
- Dark_Lightning
They are about 26” dia x 3” thick
View wildwoodbybrianjohns's profile
2128 posts in 431 days
#3 posted 10-09-2020 05:53 AM
The liquid slop on insecticides dont work. Ask me how I know. Maybe as a preventative, but not as a cure. Got a friend with a pizza oven?
-- Wildwood by Brian Johns: The Big Bang: Nothing - exploded into Everything. Thanks to Nothing.
View Robert's profile
Robert
4052 posts in 2364 days
#4 posted 10-09-2020 11:02 AM
Build a small kiln.
View 4wood's profile
4wood
61 posts in 837 days
#5 posted 10-10-2020 12:42 AM
Here is one of the best websites for wood information. Heating the wood so that the internal temperature is maintained at 130 degrees F. for a period of time will kill insects. Here is a quote from Dr. Gene That I copied from the website I attached below.
From Professor Gene Wengert, Sawing and Drying Forum technical advisor:
I would question whether you can fumigate white oak without using special procedures that would be very expensive. The property that keeps water (wine or whiskey) in a white oak barrel will also keep the fumigation gas out. Therefore, use heat. You only need to get the wood up to 130 throughout for 30 minutes to do the trick. The 160 F quote you have is likely for softwoods for setting the pitch.
https://www.woodweb.com/cgi-bin/search/search.cgi?Realm=All&Terms=heat+to+kill+insects&submit.x=16&submit.y=8#reference.
It may be possible to make a container using foil backed foam insulation and heating it with with something safe. A cargo trailer may also work. I imagine you could buy a thermometer online to place into the interior of each cookie that you would be able to monitor on the outside of the container.
tool_junkie
#6 posted 10-18-2020 02:48 AM
Guys, thank you so much for the information. I will try these suggestions.
Robert
#7 posted 10-18-2020 02:23 PM
I air dry a fair amount of wood, Borate treatment seems to work well for me.
Kiln drying to kill insects seems to me like closing the barn door after the horse it out. Insect damage could already have occurred.
You can make a small kiln using a space heater pretty easily.
