Klean strip green and shellac color on birdseye and paduak help.
Forum topic by OldBull posted 10-03-2020 03:29 PM 517 views 0 times favorited 6 replies Add to Favorites Watch
View OldBull's profile
OldBull
336 posts in 312 days
10-03-2020 03:29 PM
Good morning,
I am still inching forward and far from ready to shellac anything but I am getting closer. While at the store I bought denatured alcohol “Klean strip Green” before knowing all alcohols are not the same (although they use to be the same at 2 am on a friday night when I was younger). Shellac.net calls the green a good choice as it has less methanol and more ethanol. My question is dissolve time and shellac choice. I am looking for your help with expectations, suggestions, tips etc for using the green denatured alcohol with shellac and what color shellac you like. A week to dissolve is a long time but if it is a week then that’s what has to be done. Can I plan on lumps and clumps even if I stir-shake-swirl religously? Can I use one color shellac for both padauk and maple or should I expect a color problem?
Someone even said 99% rubbing alcohol was even better/faster.
I know it is a lot but any help would be appreciated. I have done a ton of reading and watching but applying a finish seems to be a subject that is very contradictory and even polar opposite at times.
Thanks for the help
Donny
View Planeman40's profile
Planeman40
1536 posts in 3778 days
#1 posted 10-03-2020 07:45 PM
I keep a glass jar of “seed shellac” in my paint cabinet. Mixing is no problem. Just mix the right proportions and shake the jar until it is all dissolved. I then strain the mixture through some cheap nylon stocking material. I generally make my shellac up somewhat thick and then thin it with alcohol until I get what I want.
View SMP's profile
SMP
3469 posts in 922 days
#2 posted 10-03-2020 09:13 PM
Are you wanting to mix it up from flakes you already have? I use the zinsser clear on the woods you mention and like the look of it personally.
View jacww's profile
jacww
75 posts in 2024 days
#3 posted 10-03-2020 09:53 PM
OldBull,
I mixed up some shellac earlier this year using the Jasco brand green denatured alcohol and had no problems. I used shellac flakes purchased from Highland Woodworking in Atlanta. After I mixed the flakes and alcohol I shook the jar occasionally. within a short time the flakes were mostly dissolved. I let it sit overnight and the flakes were completely dissolved. Like Planeman40 I strained it then used it.
TonyC
View LittleBlackDuck's profile
LittleBlackDuck
6587 posts in 1837 days
#4 posted 10-04-2020 12:05 AM
Shellac has a limited shelf life… Unless you plan to use a lot at once, mix as required… Keep mixed shellac in a fridge.
100% alcohol (Metho in Australia), though usually much dearer (and harder to source), makes a better mix than that laced with 5-10% Ethanol… though most would not notice the difference.
Though its long (1:28:38), here is a video that may give you some ideas that many do not cover (in one)... Suggest downloading and watching while consuming some good drinking alcohol.
Link to a handy cut table... and some hints in the included link in the PDF.
PS. ”Dead” shellac mixed 10:1 with non-pure metho makes a good sanding sealer. To test… put a drop or two between thumb and forefinger and tap the two together slowly for about 30 or so seconds, if it doesn’t tack up its more than likely “dead”...
View CaptainKlutz's profile
CaptainKlutz
4187 posts in 2511 days
#5 posted 10-04-2020 04:25 AM
1) There are several existing threads on the topic of shellac and alcohol types. Several due challenges California folks have finding DNA. Here is a recent one to get you started:
https://www.lumberjocks.com/topics/307277
2) Size of shellac flakes plays a large role in time to dissolve. If you use one of the those small coffee/spice grinders and turn the flake into dust, and can dissolve a new batch of shellac in 10-15 minutes of shaking due smaller size. Often find the the coffee grinders at second hand stores like Goodwill or Salvation Army for 10% of new cost.
Generally speaking, with regular agitation; should be able dissolve small flakes in 1-3 days max. If you find flakes are not dissolving and you shake/stir ~every hour; they may be contaminated with moisture, and are only capable of making snot ball in jar. Even fresh shellac can have small percentage of undissolvable flakes, and that is why you always strain off good stuff to use on the project. If you store your shellac flakes in cool and dry place; they will last a very long time. Once dissolved into alcohol, the shelf is ~6-12 months. The way to tell if shellac is old; Brush heavy coat on stick. Old shellac will never cure hard and surface stays tacky 24 hours later.
3) Color? Color in finishing is personal preference.
I use lightest blond shellac as grain sealer to minimize color shifting. Also prefer it on white woods.
Amber shellac as seal coat is nice way to add some color and depth to lighter woods, when using a water base top coat. Am not a fan of the orange-ish wood colors, so I don’t use it as the only finish.
Garnet shellac creates an awesome finish on walnut and/or cherry. Used as grain sealer, it restores some of the color lost on kiln dried/steamed walnut. Used as the top coat (french polish) really makes walnut grain pop.
Here is one LJ project example:
Click for details
On cherry, garnet shellac can be used to darken the wood and replace/accelerate some natural aging for items kept away from UV light that turns cherry dark naturally.
Hope this helps.
OldBull
#6 posted 10-04-2020 04:48 PM
Thanks everyone, sorry I am late back to the party.
