Help identifying a W&T Wood and Metal Lathe
Forum topic by pbpally posted 10-01-2020 01:59 PM 659 views 0 times favorited 8 replies Add to Favorites Watch
View pbpally's profile
pbpally
2 posts in 388 days
10-01-2020 01:59 PM
Topic tags/keywords: walker and turner walker and turner lathe lathe help identification question resource
Hi folks.
Need help identifying this Walker and Turner “wood and metal” lathe that is for sale near us.
I am told it is from the ‘50s. Just wanted any clarifying information one might have about it and, if all works well, what it would be a good buy at price-wise? Also curious if you see anything missing or beaming out at you
from the photos?
8 replies so far
View ibewjon's profile
ibewjon
2649 posts in 4038 days
#1 posted 10-01-2020 02:33 PM
I paid $450 for a powermatic 90 two years ago. A 1973 model. Unless it is a collector’s item, don’t go too high. Parts, if needed, could be a problem. Bearings should be available. I would offer $100 to start.
View Planeman40's profile
Planeman40
1559 posts in 4006 days
#2 posted 10-01-2020 03:59 PM
First of all, that is a wood lathe, NOT a metal lathe. Second, Walker turner made very good woodworking tools. I have a Walker Turner WW-2 vintage cast iron 14” bandsaw still going strong. As above, I think $100 is a good starting offer. No more than $200 final price.
pbpally
2 posts in 388 days
#3 posted 10-01-2020 04:02 PM
How does one identify whether or not it is a wood AND metal lathe?
Also, unfortunately, the buyer got back to me with their asking price after i had the opportunity to post this. They’re starting price is $1,650….
- Planeman40
ibewjon
#4 posted 10-01-2020 04:14 PM
Metal lathes use different tool holder and chucks. Let it go, you can get a lot of modern lathe for that price.
View CaptainKlutz's profile (online now)
CaptainKlutz
4903 posts in 2739 days
#5 posted 10-01-2020 07:40 PM
Welcome to LumberJocks!
Suggest you surf over to Vintagemachinery.org and look at the picture archive they have on Walker Turner lathes. WT made both metal and wood lathes, but mostly find wood lathes.
http://www.vintagemachinery.org/mfgindex/detail.aspx?id=808&tab=4
Best Luck!
-- If it wasn't for bad luck, I wouldn't have no luck at all, Doom, despair, agony on me… - Albert King - Born Under a Bad Sign released 1967
View Loren's profile
11275 posts in 4893 days
#6 posted 10-01-2020 07:46 PM
$1650 is obscene for that lathe unless it’s really quite heavy, which I doubt. I’m curious what they’re asking for the other machines.
View MrUnix's profile
MrUnix
8774 posts in 3444 days
#7 posted 10-01-2020 08:07 PM
Wood lathes have a tool rest (mounted on a ‘banjo’) that you freehand the chisels on as you turn. Metal lathes don’t, and instead use a cross-slide and fixed cutting bit arrangement that is moved mechanically.
Also, unfortunately, the buyer got back to me with their asking price after i had the opportunity to post this. They re starting price is $1,650….
- pbpally
The guy is nuts – are you sure that wasn’t for all of the tools shown? IIRC, W/T only made one lathe in the 50’s – a 12” wood lathe with either a variable speed or 4 speed stepped pulley arrangement. As mentioned, you can find nice 12” lathes for significantly less money and maybe even in better shape and with more accessories.
View MrRon's profile
MrRon
6187 posts in 4488 days
#8 posted 10-09-2020 09:26 PM
As a wood lathe, it looks to be in excellent condition and isn’t missing anything. It is not a “metal” lathe. I would go no higher than $200 for it only because there are a lot of wood lathes on the market for less than $200, but I would not compare a WT lathe to a Harbor Freight lathe.
