Cutting Stars
Forum topic by Charlie81 posted 10-01-2020 01:52 PM 330 views 0 times favorited 9 replies Add to Favorites Watch
View Charlie81's profile
Charlie81
9 posts in 28 days
10-01-2020 01:52 PM
Topic tags/keywords: tablesaw arts and crafts
I am trying to learn how to cut the angles for a raised or 3D star. and how to size them. Any suggestions will be
greatly appreciated. Been doing woodworking for several years but I am still learning.
-- Charlie J81
9 replies so far
View John Smith's profile
John Smith
2735 posts in 1049 days
#1 posted 10-01-2020 04:22 PM
welcome to the forum, Charlie.
what size are your stars and how many will you make ?
can you pull an example photo from the net to put us on the same page as you ?
-- there is no educational alternative to having a front row seat in the School of Hard Knocks. --
View SMP's profile
SMP
2678 posts in 791 days
#2 posted 10-01-2020 04:30 PM
I was going to try to make some of these last Christmas but got overwhelmed and made some other things instead. Maybe this will hep get on the right track:
https://m.youtube.com/watch?v=N7hckWV84pM
Charlie81
9 posts in 28 days
#3 posted 10-01-2020 05:03 PM
I am planning about 6, 8” Stares
trying to figure out how to get photo from desk top to here
-- Charlie J81
John Smith
#4 posted 10-01-2020 09:16 PM
View AlaskaGuy's profile
AlaskaGuy
6115 posts in 3195 days
#5 posted 10-01-2020 10:15 PM
Posting pictures
https://www.lumberjocks.com/CricketW/blog/114193
Charlie81
9 posts in 28 days
#6 posted 10-02-2020 03:18 AM
Hay it worked!!!
Thanks for the help
-- Charlie J81
View hockeyfan_019's profile
hockeyfan_019
46 posts in 118 days
#7 posted 10-02-2020 07:07 PM
I actually created a sort of “rotary jig” last year, where you would screw down the wood blank to the base, and there was a “angled plate” on top where you put your router in place with a flat-ended cutter. You just had to fix the router plate at say “12:00” on the base, work the router to hog off material around 1 “arm” of the star, then rotate the top jig by 360/5=72 degrees, then repeat for the other 4 arms.
In theory it works, and I created several this way, but I think you will find accuracy is the key to a good result. If there are ANY discrepancies in the angles from arm1 to arm2 for instance, the result looks wonky. I was trying to make them for a wooden flag project, but in the end I just used the best one I made, created a silicone mold, and then cast a bunch more out of resin and painted them.
Getting all the angles reliable accurate and repeatable is very tricky for such a project. Good luck though!
-- Most of my tools are older than I am
View MrUnix's profile
MrUnix
8243 posts in 3085 days
#8 posted 10-02-2020 07:44 PM
A quick google search for 3D stars on this site (lumberjocks) turns up a lot of info. I know that there are a couple members here who make quite a lot of them, and I’ve seen several discussions about them over the years. The first few search results turned up Aggie’s blogs on the subject, which has some good reading:
3D Stars #1: Program for Calculating Dimensions and Angles for 3D Stars by Aggie69
3D Stars #2: Compound Angle Cutting Jig with Hold Downs for a Radial Arm Saw
3D Stars #3: Making 3-D Stars
Plenty more where those came from… enough to keep you busy for a while at least :)
View northwoodsman's profile
northwoodsman
392 posts in 4632 days
#9 posted 10-02-2020 08:25 PM
- SMP
Great video once I got over my anxiety attack when he went through the math. A recommended watch. If he added a stop or two it would take out all of the guess work and sneaking up on the cut,
-- NorthWoodsMan
