Look at this COOL unique Book Case
Forum topic by Joe Lyddon posted 09-29-2020 04:36 AM 982 views 0 times favorited 22 replies Add to Favorites Watch
View Joe Lyddon's profile
Joe Lyddon
10946 posts in 4938 days
09-29-2020 04:36 AM
Topic tags/keywords: unique glass bookcase glass bookcase awesome
OK, forget about the subject matter of this video…
Instead, LOOK at the BOOKCASE in the background…
I think it’s just AWESOME!
Made of mostly 1×2’s and Glass… The glass is probably more expensive than the wood would have been… BUT…
It is SO COOL!
How are the glass shelves installed?
How long is each glass shelf?
How thick are the glass shelves? (1/4” 3/8”?)
What kind of glass is used?
Again, pay no attention to the subject matter, unless you’re interested in it…
It’s the bookcase that turned me ON!
Here is where the video is, on YouTube...
-- Have Fun! Joe Lyddon - Alta Loma, CA USA - Home: http://www.WoodworkStuff.net ... My Small Gallery: https://www.ncwoodworker.net/forums/index.php?media/albums/users/joe-lyddon.1389/
22 replies so far
View robscastle's profile
robscastle
7446 posts in 3090 days
#1 posted 09-29-2020 07:47 AM
Hello Joe
Yep very impressive I think I saw an even bigger one at LBD,s place he is an avid reader.
I would expect The glass to be tempered safety glass and yes t would be expensive.
Its possibly just sitting in rebates or recesses
I suspect its 3/8 as 1/4 would be too thin.
If LBD happens to see it he may provide a SME comment.
-- Regards Rob
View Loren's profile
10720 posts in 4534 days
#2 posted 09-29-2020 11:38 AM
I’d consider sliding the glass in from the ends, assuming it could be fastened to the wall prior. I assume the glass panels are one or two segments wide.
View Jim Jakosh's profile
Jim Jakosh
25346 posts in 3991 days
#3 posted 09-29-2020 12:33 PM
That is one huge shelving unit. All the shelves look to be individuals setting on a wide support at the divider.
Cheers, Jim
View Tony1212's profile
Tony1212
456 posts in 2620 days
#4 posted 09-29-2020 12:44 PM
For those that do not want to look at the video, the book case looks like an oak ladder frame with glass shelves that the books sit on.
It looks like the wood is oak stained to that 80’s oak color. I think I see the crossmembers inserted into dadoes of the uprights.
Of course, I can only see the corner where they meet, but I assume there wouldn’t be any room to slide the glass in once the wood is secured to the wall. I think you could bring in the oak frames and slide the glass shelves in then space the frames out evenly and slide it back to the wall. I think 2 people could reasonably do it.
-- Tony, SW Chicago Suburbs
View doubleDD's profile
doubleDD
9735 posts in 2929 days
#5 posted 09-29-2020 01:19 PM
It would make a great compliment to those that have other glass furniture around their home. That’s a lot of dusting going on there.
View MPython's profile
MPython
310 posts in 698 days
#6 posted 09-29-2020 04:16 PM
DITTO, doubleDD. I showed these to my wife thinking I would offer to build her a set for her study. She nixed it immediately because of the dust issue. I like the look very much, but it’s not my call.
Joe Lyddon
#7 posted 10-01-2020 04:06 AM
DITTO, doubleDD. I showed these to my wife thinking I would offer to build her a set for her study. She nixed it immediately because of the dust issue. I like the look very much, but it s not my call.
- MPython
Yep, I know how that goes… I didn’t even Think of the dusting issue…
Oh well, we can dream can’t we? :)
View Meisterburger's profile
Meisterburger
13 posts in 124 days
#8 posted 10-01-2020 01:28 PM
The glass is shorter in length than it might appear. Look down by her right shoulder and you will see the glass joint on the wood rail. Build the ladder frames and drop in the glass panels.
Joe Lyddon
#9 posted 10-01-2020 05:54 PM
- Meisterburger
From the Back?
I can see, without the 1×2’s, lay the glass shelves in, insert the 1×2’s to hold the glass in place, etc. Make sense?
Each initial Vertical 1×2 with only mortises to hold the Horiz. shelves, which are inserted one shelf at a time as it’s built?
How will a shelf be replaced if ever broken?
View AndyJ1s's profile
AndyJ1s
465 posts in 641 days
#10 posted 10-01-2020 07:11 PM
From a practical point of view, I like the glass shelves up high, so you can see the contents from below (if they are dusted regularly).
-- Andy - Arlington TX
Joe Lyddon
#11 posted 10-01-2020 07:22 PM
I like the glass because it’s thinner than wood shelves and can get more shelves in a Case.
No trim, etc. to mess with…
Maybe the use of an compressed Air unit with an spray head would work easier than using a dust cloth?
... I’m not a Duster… :) Then, have an air cleaner unit to clean the air! :)
View pottz's profile
pottz
11736 posts in 1870 days
#12 posted 10-01-2020 07:23 PM
thats a very cool look but yeah the dusting to keep em looking good,forget it.id say the glass looks to be probably 3/8,and good question joe how would you ever replace one if needed.
View HorizontalMike's profile
HorizontalMike
7898 posts in 3800 days
#13 posted 10-01-2020 07:50 PM
- MPython
Very nice clean look! The ONLY thing that I would add, would be sliding glass doors to complete the look AND add dust-resistant shelving. 8-)
Joe Lyddon
#14 posted 10-01-2020 07:58 PM
- MPython
- HorizontalMike
... or folding doors like in those Law Book Cases… (forgot the tech. name of’em)...
Lift’em, push them back, pull out, & drop’em down to cover…
Would make it more complicated to put together… wouldn’t it? :)
HorizontalMike
#15 posted 10-01-2020 08:15 PM
- MPython
- HorizontalMike
... or folding doors like in those Law Book Cases… (forgot the tech. name of em)...
Lift em, push them back, pull out, & drop em down to cover…
Would make it more complicated to put together… wouldn t it? :)
- Joe Lyddon
Yeah, that would be too much like a Barrister’s bookcase, like what I built. Shoot, I see millionaire houses with complete sliding floor-to-ceiling glass doors. I know it could be done, but not by us paupers!
