I just went through over 250 threads in Jigs and Fixtures, and couldn't find where to post this, so I will make yet another.
I've been using a modified stool box to prop work up. It has evolved into a versatile thing (?) in my shop. Mainly, it is just three different heights in one blocky frame. It helps me get larger pieces of work up closer to my shoulders and eyes, or I can sit on it to get my eyes down to just the right level. I know it's stupidly simple, but really useful.
I recently used it while putting hinge mortices in a new door. I wish I had taken a picture, but I'm not going to take the door down now. Look at the black board and pretend it is a French door. My end vice held the door steady and the box (centered) kept it high enough to work on. No other support was needed.
It vaguely reminds me of a much smaller machinist's 123 block (it is those dimensions in inches).
This stool/box/thing is 11" x 15" x 19". I think it might be better a bit larger than 19", but the 11" seems close to minimum so it doesn't tip. It should be a lot lighter weight. I don't even have to use my hands, I just kick it over and around, and kick it under my bench when not in use. I drape an old t shirt over it when i need to work on finished pieces.
One very important feature is that the largest dimension has to be correct to sit on with a beer. In fact, it has carried my weight much more often than that of my work.
I hope to remake this nicer, with better wood. Perhaps some spiffy, lightweight Japanese joinery, decorative wood species…
Is this something everyone already uses? I'm gonna bet that someone posts something like "yes, that's a common 17th century … " Hopefully they do, I'd like to know what to call it instead of a stool-box-prop-thing.
