Best Adhesive for Stainless Steel to Wood
« back to Joinery forum
Forum topic by wilschroter posted 09-27-2020 12:00 PM 345 views 0 times favorited 6 replies Add to Favorites Watch
View wilschroter's profile
wilschroter
158 posts in 1408 days
09-27-2020 12:00 PM
I need to run a bead of adhesive around the perimeter of some stainless steel access doors that I’m putting on my outdoor kitchen. The face of the cabinets is wood (with a coat of poly).
What’s the best way to connect wood and metal? Would liquid nails work?
View John Smith's profile
John Smith
2726 posts in 1046 days
#1 posted 09-27-2020 12:04 PM
is it possible to drill holes in the metal and use screws from the back ???
then the wood would be removable, for any kind of maintenance, repair, etc.
100% GE clear silicone works for me. 3M-5200 or 5400 marine sealant is permanent, but $$.$$
photos of your project would be nice to see.
-- there is no educational alternative to having a front row seat in the School of Hard Knocks. --
wilschroter
#2 posted 09-27-2020 12:24 PM
The metal access doors in this picture.
View MPython's profile (online now)
MPython
310 posts in 695 days
#3 posted 09-27-2020 02:09 PM
Wow! That looks really nice!
View Sark's profile
Sark
341 posts in 1243 days
#4 posted 09-27-2020 02:29 PM
Polyurethane based construction adhesive/sealant will make a tough flexible bond. Lots of brands from which to choose: Gorilla, Sikaflex, etc…. Available to HD in tubes and in different colors. Must be polyurethane based, it’s very stick stuff.
Really really hard to remove when cured, so if you expect to redo or maintain in a few years or decades, then go with the pure silicone, as John recommends. I had a job once taking out some 2×6’s stuck to a concrete floor with Sikaflex. What a nightmare.
View CaptainKlutz's profile
CaptainKlutz
3722 posts in 2377 days
#5 posted 09-27-2020 04:16 PM
Cool looking kitchen!
As long as the stainless steel (SS) is not mirror polished, most any adhesive will work.
Since you want to bond back side, can roughen the surface with 36/60grit and clean with solvent; and any water resistant adhesive will work.
If SS is mirror polished, need adhesive with special etch/bond chemistry. There are grey color silicone caulk/adhesive materials developed for commercial kitchen installations that provide best bond on polished SS.
Note that you do not want to use a silicone caulk that smells like vinegar on any appearance metals. The acetic acid generated by catalyst can discolor even SS over time as moisture moves in/out of the bond. You want the newer style methyl based systems that liberate an alcohol smell as they are exposed to air.
Best Luck.
View LesB's profile (online now)
LesB
2623 posts in 4326 days
#6 posted 09-27-2020 04:22 PM
How about a “rubber” gasket?
-- Les B, Oregon
