grain direction
« back to Woodturning forum
Forum topic by telrite posted 09-27-2020 12:59 AM 280 views 0 times favorited 4 replies Add to Favorites Watch
View telrite's profile
telrite
100 posts in 3178 days
09-27-2020 12:59 AM
I am building a platter and want to put a 1/4 spacer in between 16 segments. The segments are 2.1/4 wide by 5 long. The grain in the segments are running the right direction. I want to use Ebony as the spacer. Will I be asking for trouble if I run the spacer grain the other direction or should i glue up enough ebony to run it the same direction as the segments. I am worried that a cross grain piece that small will crack.
View TheDane's profile
TheDane
5866 posts in 4546 days
#1 posted 09-27-2020 02:57 AM
How many segmented layers?
telrite
#2 posted 09-27-2020 10:08 AM
I plan on about a 3” disc on the bottom an maybe a 1” segmented ring around the ton top
TheDane
#3 posted 09-27-2020 02:03 PM
I ask because end-grain glue joints (which is what you have when constructing a segmented ring) are notoriously weak. End-grain to side-grain joints are only marginally stronger.
Unless the rings are supported with face-grain glue joints, you are likely to experience glue joint failure … which is why segmented turners use a ‘brickwork’ pattern when stacking rings.
I don’t think a 3” disc is going to provide enough glue surface to adequately support a 10” ring.
telrite
#4 posted 09-28-2020 01:45 AM
So I have gone with a 1/8 spacer The segments are just over 2 wide but 5 long. i plan on putting another ring on the top to help tie it together so I guess it will end up being a shallow bowl. The points come to about 1” from joining so yes i will put a floating disc bottom
